way to limit switch ports speed to 100 FULL max but using auto negotiation
yann.boulet
Hi everybody,
I wan to know if it's possible in Cisco switch 2960S that support 1G per ports to limit the speed to 100 and duplex to Full at max but using the auto negotiation process for the end device.
thx
6 Replies 6
Stephane Bonnet
Hi Yann,
What you looking for can be found in the Cisco 2960S Configuration Guide at the following section "Classifying, Policing and Marking Traffic on Physical Ports by Using Policy Maps"
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_53_se/configuration/guide/swqos.html#wp1044737
Stephane
thank you for the quick reply but I have just checked IOS features and I can see that a new option exists about " SPEED AUTO 100"
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/prod_bulletin0900aecd80122f85.html
so it means the switch is able to limit the speed to 100 and let the auto negotiation process to work.
thanks
Interesting, but as you can see this technology isn't available on  C2960S only on 2970, 3750 & 3560.
I just check on my own on Feature Navigator and it's interesting because Cisco state that only these platforms are supported for the feature you asking for:
Forced 10/100 Autonegotiation
The forced 10/100 autonegotiation feature provides an option to limit  interface speed autonegotiation to 100 Mbps or less on a  10/100/1000BASE-T port.
Platform Tree
Cat4948 with different models
Cat4900M
Cat4500 & C4500E with different sup card and IOS or IOS XE
Stephane
I saw that it was not supported on the 2960S but it is, I have just configured the port with "SPEED AUTO 100" so it works on 2960S platform
Yes it's in the Conf Guide of the C2960S:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_53_se/configuration/guide/swint.html#wp1080632
And in fact, this isn't the same feature that i find on Cisco Feature Navigator.
Yours block the negociation to the specified speed it is not possible to have another, the "Forced 10/100 Autonegociation" permit to do negociation of 100Mbps or less, this one goes beyond and it is limited effectively to certain type of Catalyst.
Stephane
The command "speed 10 100" is available to the 2960/2960S.  I have this command configured.
