WCCP command not accepted on 3750 switch
I'm trying to configure WCCP redirection using L2 forwarding on a 3750 Stack but the "ip wccp web-cache" command is not accepted.
Can you please help?
Stack_3750X(config)#ip wccp
% Invalid input detected at '^' marker.
Using version 15.0
Stack_3750X#sh ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.0(2)SE6, RELEASE SOFTWARE (fc2)
SDM prefer routing enabled.
Stack_3750X#sh sdm prefer
 The current template is "desktop routing" template.
 The selected template optimizes the resources in
 the switch to support this level of features for
 8 routed interfaces and 1024 VLANs.
  number of unicast mac addresses:                  3K
  number of IPv4 IGMP groups + multicast routes:    1K
  number of IPv4 unicast routes:                    10.875k
    number of directly-connected IPv4 hosts:        3K
    number of indirect IPv4 routes:                 7.875k
  number of IPv6 multicast groups:                  64
  number of IPv6 unicast routes:                    32
    number of directly-connected IPv6 addresses:    0
    number of indirect IPv6 unicast routes:         32
  number of IPv4 policy based routing aces:         0.5K
  number of IPv4/MAC qos aces:                      0.375k
  number of IPv4/MAC security aces:                 0.875k
  number of IPv6 policy based routing aces:         0
  number of IPv6 qos aces:                          0
  number of IPv6 security aces:                     58
Here is the license:
Stack_3750X#sh license
Index 1 Feature: ipservices
        Period left: Life time
        License Type: PermanentRightToUse
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
        License Count: Non-Counted
Index 2 Feature: ipbase
        License State: Active, In Use
        License Priority: Medium
Index 3 Feature: lanbase
        Period left: 0  minute  0  second
Mark Malone
9 Replies 9
Mark Malone
Hi ipbase does not support wccp you need ipservices or advanced license
http://www.cisco.com/c/en/us/support/docs/security/web-security-appliance/118006-configure-wccp-00.html
Mark
Thank you Mark, I've seen that, but I also need to unstack the switches to enable ipservices feature, otherwise the license state remains to "Not in Use, EULA not accepted" status, the "license boot level ipservices" has no effect.
if there stacked you should be able to install the license to each switches flash and then reboot the stack without having to take it down
example from one of our stacks--load to each flash do a show license detail then save and reboot stack and each switch should come up with the new license once there valid
I did the following commands, saved and rebooted but it did not solve:
Stack_3750X(config)#license boot level ipservices switch 1
Stack_3750X(config)#license boot level ipservices switch 2
Stack_3750X(config)#license boot level ipservices switch 3
I still have:
Here is what I get in details.
Stack_3750X#sh license detail switch 1
Index: 1        Feature: ipbase                            Version: 1.0
        Store Index: 0
        Store Name: Primary License Storage
Index: 2        Feature: ipbase                            Version: 1.0
        License Type: Evaluation
        License State: Inactive
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
            Period used: 0  minute  0  second
        Store Index: 2
        Store Name:
Index: 3        Feature: ipbase                            Version: 1.0
        Store Index: 3
        Store Name:
Index: 4        Feature: ipservices                        Version: 1.0
            Evaluation period left: 8  weeks 2  days
            Period used: 1  day  23 hours
            Expiry date: May 27 2011 01:45:34
        License Priority: Low
        Store Index: 0
        Store Name:
Index: 5        Feature: ipservices                        Version: 1.0
        Store Index: 1
        Store Name:
Stack_3750X#sh license detail switch 2
        Store Index: 0
        Store Index: 2
        Store Name:
        Store Index: 3
        Store Name:
            Period used: 40 weeks 0  day
        Store Index: 1
        Store Name:
            Evaluation period left: 0  minute  0  second
            Period used: 8  weeks 4  days
        Store Index: 0
        Store Name:
Stack_3750X#sh license detail switch 3
        Store Index: 0
        Store Index: 2
        Store Name:
        Store Index: 3
        Store Name:
            Expiry date: May 27 2011 01:58:26
        Store Index: 0
        Store Name:
        Store Index: 1
        Store Name:
Stack_3750X#
Note there is a mismatch between the 3 switches. Are you sure I do not need to unstack them ?
no you dont need to break the stack to upgrade licenses heres another link someone else answered to regarding that
https://supportforums.cisco.com/discussion/11059381/how-upgrade-license-stacked-c3570e
Looking at your outputs there eval licenses have you actually installed the ipservcies licenses to each flash in the stack or are you planning on using eval as they will run out  , the license boot commands will only work if the actual ipservices license is installed in each flash using license install from my previous screenshot and then use your license boot to pick which license to run on each switch , each switch needs to be set the same
I did not install the licenses myself (I took the switches as they were, it's for lab purposes) and preferably I'd prefer permanent licenses than evaluation.
Under the file system (flash:x...) I cannot located any .xml licence file.
Example:
Stack_3750X#dir flash1:
Directory of flash1:/
    2  -rwx        9678  Mar 30 2011 01:34:19 +00:00  private-config.text
    3  drwx         512   Mar 3 1993 20:34:17 +00:00  c3750e-universalk9-mz.150-1.SE2
  468  -rwx         856  Mar 30 2011 01:29:51 +00:00  vlan.dat
  469  -rwx        6190  Mar 30 2011 01:30:10 +00:00  config.text.backup
  470  -rwx        9678  Mar 30 2011 01:30:10 +00:00  private-config.text.backup
  471  -rwx        6192  Mar 30 2011 01:34:19 +00:00  config.text
  472  -rwx        3096  Mar 30 2011 01:30:10 +00:00  multiple-fs
  473  drwx         512  Mar 30 2011 02:06:13 +00:00  c3750e-universalk9-mz.150-2.SE7
  998  drwx         512  Mar 30 2011 02:06:13 +00:00  dc_profile_dir
Do you have any idea?
Hi yes ipservices license are very expensive you need to buy them off Cisco but if its just for testing you can run eval licenses for a few weeks and then revert back to the ipbase license
see this regarding your output above where eval is not working right , you need to reboot them and accept eval
https://supportforums.cisco.com/discussion/11178776/uprading-license-ipbase-ipservices-3750x-stack
Ok, I finally found the solution. I did the following commands, saved and rebooted:
Stack_3750X#license right-to-use activate ipservices switch 1 acceptEULA
Stack_3750X#license right-to-use activate ipservices switch 2 acceptEULA
Stack_3750X#license right-to-use activate ipservices switch 3 acceptEULA
So now the WCCP command works:
Stack_3750X(config)#ip wccp ?
  <0-254>           Dynamically defined service identifier number
  source-interface  Set source interface for Router ID
  version           protocol version
  web-cache         Standard web caching service
ah good stuff
