09-29-2016 05:42 AM - edited 03-08-2019 07:37 AM
What cable and connector to use for the Cat-3650 4 x Gigabit-interfaces? the normal RJ-45 with cat6 cables does not connect
Solved! Go to Solution.
09-29-2016 07:43 AM
From experience never buy anything that the switch does not have listed as supported , here is what 3650 can connect with
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html
Network Device |
Transceiver Module |
Minimum Software Release Required |
DOM Support |
Cisco IOS Release |
WS-C3650-24TS WS-C3650-24PDM3 |
GLC-T (10/100/1000) |
XE 3.3.0SE |
XE 3.3.0SE |
GLC-BX40-D-I |
XE 3.7.1E |
XE 3.7.1E |
09-29-2016 07:26 AM
there fibre ports so you can either use a GLC-T 1000 base and then you can use copper cat6 , bascaiily fibre to copper converter
or insert an actual fibre SFP like GLC-SX-MM an use LC-LC cabling or some other fibre type depending distance and what you require locally
09-29-2016 07:29 AM
I found this on cisco website, not sure it is built for this purpose or not.
(10-Gigabit Ethernet CX1 Copper Connector)
can you confirm, if that is through to order it ?
09-29-2016 07:33 AM
no I wouldn't get that those ports don't support 10gb there 1gb module ports
https://www.amazon.com/s/ref=nb_sb_noss/152-4413069-2764139?url=search-alias%3Daps&field-keywords=GLC-T+1000+base
09-29-2016 07:41 AM
But if the CX1 supports 1gb , it is enough for me. can I go with that ? because it is cisco product
09-29-2016 07:43 AM
Network Device |
DOM Support |
Cisco IOS Release |
XE 3.3.0SE |
XE 3.3.0SE |
GLC-BX40-D-I |
XE 3.7.1E |
XE 3.7.1E |
09-29-2016 07:47 AM
Thanks a lot Mark
09-29-2016 07:29 AM
Are you referring to the uplink ports (fiber)?
For the user side, you can use copper but for the uplinks you would need to use fiber transceivers with fiber patch cords.
09-29-2016 07:38 AM
Yes I m referring to the 4-uplink ports. I want to interconnect two Cat-3650 switches. does cisco offers the fiber transceivers with patch cords ? if yes, can you please tell me the part-number. I couldn't find it on cisco
