01-15-2016 12:42 AM - edited 03-08-2019 03:25 AM
Hello Guys,
Can some brief me the CEF technology. How it works? If you can brief with example would be better.
Thanks in advance.
01-15-2016 01:05 AM
Hi basically it takes the burden off the CPU on a switch it is a layer 3 advanced switching technology that caches the routing table to speed up switching
Extract
CEF uses a FIB to make IP destination prefix-based switching decisions. The FIB is conceptually similar to a routing table or information base. It maintains a mirror image of the forwarding information contained in the IP routing table.
Cef table has cached copy of route below for fast switching so it does not have to look up every time
CORE#sh ip route 189.x.x.x
Routing entry for 189.x.x.x/24
Known via "eigrp 1", distance 170, metric 52224
Tag 12, type external
Redistributing via eigrp 1
Last update from 172.x.x.x on Port-channel5, 1w2d ago
Routing Descriptor Blocks:
172.21.253.6, from 172.21.253.6, 1w2d ago, via Port-channel5
Route metric is 52224, traffic share count is 1
Total delay is 40 microseconds, minimum bandwidth is 50000 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 4/255, Hops 3
Route tag 12
* 172.21.253.2, from 172.21.253.2, 1w2d ago, via Port-channel4
Loading 6/255, Hops 3
Route tag 12
CORE#sh ip cef 189.x.x.x
189.x.x.x/24
nexthop 172.21.253.2 Port-channel4
nexthop 172.21.253.6 Port-channel5
CORE#
01-15-2016 01:08 AM
Thank You very much Mark. Appreciate your response.
01-15-2016 01:25 AM
In addition to Mark's response, in the CCIE Routing and Switching v5.0 Official Certification Guide, Volume 1 book from Cisco Press I co-authored with Narbik Kocharians, I have done a deep-dive into CEF, and fortunately, precisely the chapter with the CEF description including examples is available for free download here:
http://www.ciscopress.com/content/images/9781587143960/samplepages/9781587143960.pdf
Happy reading ;)
Best regards,
Peter
P.S.: Cisco also has a document about CEF here - it is somewhat shorter and not written by me but we reused some of the figures in the Cisco Press book:
http://www.cisco.com/c/en/us/support/docs/ip/express-forwarding-cef/13706-20.html
01-15-2016 01:33 AM
Thanks...Peter. Appreciate your response.
01-15-2016 10:26 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Very briefly, it's a way to do destination IP to route lookups very fast. How it does that might not easily be explained briefly because variable length route prefixes makes the issue complex. Peter's references explain the "how".
The slowness of destination IP to route lookups, before CEF, was such is why you had sayings like "switch when you can, route when you must", tag switching (which became MPLS), and various different route caching techniques.
