09-26-2007 05:00 AM - edited 03-05-2019 06:42 PM
I couldn't fins any docs which describes the certified operating temp. for this module, and with "show env" the temp seems to be quite high.
module 1:
module 1 power-output-fail: OK
module 1 outlet temperature: 45C
module 1 inlet temperature: 31C
module 1 aux-1 temperature: 47C
module 1 aux-2 temperature: 37C
module 1 asic-1 (SSA-1) temp: 66C
module 1 asic-2 (SSA-2) temp: 62C
module 1 EARL outlet temperature: 39C
module 1 EARL inlet temperature: 35C
Does anyone know the "limits" or is there a doc. with specification.
THX
Emanuel
09-26-2007 05:42 AM
Hi Emanuel,
Pls check this link.It may help you.
http://www.cisco.com/en/US/netsol/ns668/netqa0900aecd80534905.html
09-28-2007 01:44 AM
Thx for reply. I already had this info.
I'm looking a spec. for the ASIC temp.
Is there any information available ?
09-28-2007 01:54 AM
Hope this helps you.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_data_sheet09186a00801dce34.html
It contains the info you are looking for.
09-28-2007 02:13 AM
unfortunately not.
Where you find the certified max operating temp. for ASICs. This also just says operating temp for the module itselfe.
I'm looking for the asic spec. 'cause they are running at over 60 degrees.
06-22-2014 10:15 PM
Did you find answer to your question about ASIC temperature threshold? How did you handle this issue?
