What is the purpose of the ROMMON F1 and F2 and Gold regions?
choi.brendan
Beginner
Beginner
On my 6509-E, all the modules show this:
Region F1: INVALID
Region F2: INVALID
Currently running ROMMON from S (Gold) region
Is this alright? Is the Gold region like a default region where ROMMON is always installed. And are F1 and F2 just storage partitions that are available to hold backup copies of the ROMMON? From what I read, it sounds like I can copy ROMMON images to F1 and F2, either the same version as the Gold region or different versions. Is that correct? Why would I want to copy different ROMMON versions to F1 and F2? For testing, or??
Reza Sharifi
Hall of Fame Expert Hall of Fame Expert
Hall of Fame Expert
What version of IOS are you running?  If you are running an older version, you can upgrade the IOS, and that should also upgrade the Rommon for you.  If not, you can just upgrade Rommon by itself.
I'm at 12.2(33)SXI4a or something like that. Yes, I can upgrade to a higher IOS. I have also read what seems to suggest that an IOS upgrade will also upgrade the ROMMON's.
But, still, what are these F1, F2 and Gold regions for? What practical use for them?
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
They allow you to have newer ROMMON code.  Having more than one, should allow you to select which you want to boot with (the default boots with the last one loaded).
