What kind of information give me a LED of port on a switch or Router?
ZogoHUN01
Beginner
Beginner
I would to ask:
darren.g
Contributor
Contributor
ZogoHUN01 wrote:
I would to ask:
How long is a piece of string?
It depends on the router/switch/module type as to what each LED means.
On a basic, single RU, single unit switch, the port LED's usually indicate connectivity, speed or duplex - but may indicate other things, depending on the position of front panel pushbuttons (2950's, for example, toggle through several different status displays using a front panel "mode" push button).
What kind of device are you asking for information on?
Cheers.
Thanks your answer!
We use 3400 and 3750 switches in our network.
And I would to know: what does mean if the port status LED is green or amber, maybe it doesn't light?
ZogoHUN01 wrote:
Thanks your answer!
Find information on the 3750 here
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/hardware/installation/guide/HIGOVERV.html#wpxref39834
For ports, in the default (port status) mode, the LED colours mean as follows
LED Off : Port disconnected or administratively shut down
LED Green : Port link active
LED Green flashing : Port active (data flowing)
LED flashing green/amber : Link faulty. Port receiving errors - CRC, excessive jabber, alignment errors etc
LED Solid Amber : Port blocked by STP (either in learning mode or blocked owing to dual path), and not forwarding traffic
LED Blinking Amber : Port blocked by STP and sending/receiving packets
The information for the 3400 switch is here
http://www.cisco.com/en/US/docs/switches/metro/me3400/hardware/installation/guide/HIGOVERV.html#wp1269133
But the meanings are pretty much the same as the 3750.
Cheers.
(Please mark question answered if it is to your satisifaction)
Thank you!
Recognize Your Peers
