what's the difference between C7606 and C7606S?
Ray Han
hi all
what's the meaning of "S"?
is there anyone tell me about this?
Thanks~~
2 Accepted Solutions
lgijssel
Level 9
Level 9
Check the product pages:
http://www.cisco.com/en/US/products/hw/routers/ps368/prod_models_comparison.html
As part of the Cisco 7600 Series, the Cisco 7606-S Router is an enhancement on the highly successful 6-slot
chassis (Cisco 7606). This enhanced chassis delivers numerous design improvements, including:
● Improved failover mechanisms in the hardware, which when paired with the proper Cisco IOS® Software
image can achieve 100 ms failover
● Ability to deliver higher power of up to 750W per slot
● High-speed fan tray module with five speeds on a side-to-side airflow design
● Better thermal flow measurement and management
Leo
The  Cisco 7606-S Router is an enhancement on the highly successful 6-slot  chassis (Cisco 7606). This enhanced chassis delivers numerous design  improvements, including:
++   Improved failover mechanisms in the hardware, which when paired with  the proper Cisco IOS® Software image can achieve 100 ms failover
++  Ability to deliver higher power of up to 750W per slot
++ High-speed fan tray module with five speeds on a side-to-side airflow design
++ Better thermal flow measurement and management
The Cisco 7606-S chassis accommodates a broad selection of line cards supporting numerous applications, including:
++ SPAs and SIPs (Cisco 7600 Series SPA Interface Processor-200 [SIP-200], SIP-400, and SIP-600):
– Channelized T1/E1, Channelized T3, and Channelized OC-3/STM-1
– OC-3/STM-1, OC-12/STM-4, OC-48/STM-16 Packet over SONET/SDH (PoS), and OC-192/STM-64 PoS
– OC-3/STM-1 ATM, OC-12/STM-4 ATM, and OC-48/STM-16 ATM
– Fast Ethernet, Gigabit Ethernet, and 10 Gigabit Ethernet
Also for specific feature comparison between two products, i would suggest you to refer the data sheet.
7606:
http://www.cisco.com/en/US/prod/collateral/routers/ps368/ps371/product_data_sheet09186a0080088773_ps368_Products_Data_Sheet.html
7606-S:
http://www.cisco.com/en/US/prod/collateral/routers/ps368/ps371/product_data_sheet0900aecd8057f3c8.html
Cheers
Somu
Rate helpful posts
lgijssel
Level 9
Level 9
Leo
7606:
7606-S:
Cheers
Somu
Rate helpful posts
Thanks for your reply and have a good day!!
