03-01-2011 08:58 PM - edited 03-06-2019 03:50 PM
I am going to purchase 6 x Catalyst WS-C2960S-48FPD-L switches and make them into 2 stacks (because 4 is the maximum switches in a stack).
I want to connect the 2 stacks using 10GB.
What kind of transceiver and fibre cable do I need to buy in order to link the 2 stacks up using 10GB?
Are they different if I link them up with 1GB?
Thanks in advance.
Solved! Go to Solution.
03-01-2011 09:14 PM
SFP-10G-SR for 10gig
GLC-SX-MM for 1gig
you can use multimode fiber. Depending on the quality/ratings of the multimode fiber there will be distance limitations.
03-01-2011 09:14 PM
GLC-SX-MM for 1gig
03-02-2011 09:10 PM
Thanks Roman for your response.
It is a pity that 2960 can only provide at most 2 x 10GB uplink.
I wish it could provide 4 x.
