07-12-2012 02:18 PM - edited 03-07-2019 07:44 AM
I have 2 switches C4506-E with SUP7-E, does anybody knows when Cisco will support the VSS functionality? I Have read that VSS will be supported in these switches and it be available Q32012, but Cisco has not confirmed when.
Any idea could be useful.
07-12-2012 02:54 PM
My guess is sometime September 2012 or February 2013.
07-18-2012 01:25 AM
Hi Ronald,
It is currently targeted for Q4CY12.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
07-18-2012 02:20 AM
Thanks for the confirmation, Ivan.
07-18-2012 02:29 AM
welcome!
Kind Regards,
Ivan
09-20-2012 01:16 AM
Can all series 4500E supported VSS with Sup 7-E /7-LE or only switch 4506-E and 4503-E .?
this document
"http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/prod_brochure0900aecd802a492c.pdf"
says 4506-E and 4503-E support VSS.
tanks
09-20-2012 01:35 AM
Per latest information I have, all E Series chassis and all existing line cards will be supported. You will need 10G ports (4606, 4712 or the 10G ports on Sup 7E) for the VSL link.
Kind Regards,
Ivan Shirshin
09-20-2012 01:38 AM
Yes, all Catalyst 4500 E Series Chassis (3, 4, 7R, 10R slot) support VSS with supervisor Sup7-E / Sup7L-E
Aru
