which switch cheaper than 3560 switch?
contact_abdul
i ask silly question.but to save time i ask it.i want cisco switch cheaper than 3560 switch.I need POE and 10/100/1000 speed must.ok? pls reply.regards.
2 Accepted Solutions
Abdul,
Unfortunately this is the only switch which can give you PoE on 10/100/1000 interface.
There is a 2960 switch which supports PoE but on 10/100 interfaces.
So I guess no other option.
-> Sushil
Sushil
Good spot, i missed that one. Rated. The 2960G switches do support 10/100/1000 but not PoE.
Abdul - apologies for the misleading information.
Jon
8 Replies 8
Jon Marshall
The 2960 switches are probably what you want to be looking at. You don't say how many ports you need but assuming 24 or 48 there are 2 models that support 10/100/1000 + PoE
2960G-24TC-L - 24 port 10/100/1000 + PoE for all 24 ports.
2960G-48TC-L - 48 port 10/100/1000 + PoE for 24 ports only.
See this link for more details:
http://www.cisco.com/en/US/products/ps6406/prod_models_comparison.html
Be aware though that the 2960 switches are layer 2 only switches so they will not support inter-vlan routing. For a L3 switch you have to start at 3560.
Jon
Hi JOn,
I guess, 2960 TC-L model does not supports PoE + its not Gig based interface. It providse FE interfaces.
Cisco Catalyst 2960-24TC-L
24 Ethernet 10/100 ports and 2 dual-purpose uplink ports
Cisco Catalyst 2960-48TC-L
48 Ethernet 10/100 ports and 2 dual-purpose uplink ports
The PC-L switch provides PoE interfaces bu tagain its no GE but FE interfaces -
Cisco Catalyst 2960-24PC-L
24 Ethernet 10/100 PoE ports and 2 dual-purpose uplink ports
And there is no 48 port PoE model.
-> Sushil
Sushil
Jon
Hey Jon,
No Problems. This is the beauty of this forum. Ultimately the correct information goes to the user. We all keep making slips here and there :)
Being a human being I guess we should have that much liberty.
-> Sushil
thnx Jon,
Now i will take some points from sushil and give to u.kidding. regards. thnx all buddy.
thnx Jon. I needed 24 ports and 10/100/1000 and poe.
guys is there any others than cisco brand which is having same features and still cheaper than cisco? I guess i ought not discuss other than cisco here :)
regards
abdul
Abdul,
-> Sushil
Thanks to sushil and JON and others for timely response.
sushil i gave u full points :) regards.I love this forum .
engr. abdul
