which switch to use?
Hi!
Must select Cisco switch with DHCP server  for 1000 - 2000 users.
What model to choose?
Thanks!
6 Replies 6
devils_advocate
Level 7
Level 7
What other switches do you have currently if you have 1k-2k users?
What is your budget?
Why DHCP on the switch and not on a server?
Without more information its difficult to provide a meaningful answer but with the information provided, I would look at the 3850 series perhaps. They can be stacked, capable of good throughput and also can function as a WLC if required.
If money is no object, two chassis switches running VSS but this could be overkil or more likely, over budget
This is a temporary solution. Need to quickly deploy a wireless network. I want to use the switch as DHCP server. Required reliability. The budget is not big. Planned 3750 series. Рossible?
Yeah a 3750 should work for a DHCP server.
Are you thinking X or G series?
You may need an IP base image or above to do DHCP server though, I am not 100% on that one.
Thank you. 3560-C Series can be used? Good price:-)
Hmmmm I can't be sure on that one, the data sheet is a little vague on it.
May be worth contacting the reseller you go through to see if they can offer some pre sales advice.
Ок. Thanks you.
