Why choose 2960G over 2960S stand-alone?
Will White
The topic says it all- It looks like 2960S is cheaper than 2960G at same port configuration and image. Plus with the -S model you get 4 dedicated SFPs.
So wouldn't 2960S be better choice than 2960G even as a stand-alone (non stacked) access switch? Or is there something I am missing looking at the datasheets?
manju.cisco
Level 3
Level 3
I dont see any reason to choose 2960G over 2960S......
2960S has more features and more enhanced in hardware than compared to 2960G..... I believe 2960S should be a best option.
