Whyt can't we see remote network in eigrp ?
lowfell
Level 3
Level 3
I am a host in vlan 6  (9400)
ip address 10.32.253.2
interface Vlan6
description ***  Data Vlan ***
ip address 10.32.253.1 255.255.255.240
router eigrp 100
bfd interface Vlan266
bfd interface Vlan267
network 10.32.253.0 0.0.0.0
network 10.32.253.16 0.0.0.0
network 10.32.253.32 0.0.0.0
network 10.32.253.48 0.0.0.0
network 10.32.254.1 0.0.0.0
network 10.32.254.6 0.0.0.0
network 10.32.254.10 0.0.0.0
network 10.32.254.13 0.0.0.0
passive-interface default
no passive-interface Vlan266
no passive-interface Vlan267
the address I'm trying to reach is 172.16.4.4 his gateway is 172.16.4.1
I can ping both  addresses from my switch but not from the end devices
Here is my route
#sho ip route 172.16.4.4
Routing entry for 172.16.4.0/22
Known via "eigrp 100", distance 90, metric 3072, type internal
Redistributing via eigrp 100
Last update from 10.32.254.9 on Vlan267, 00:02:03 ago
Routing Descriptor Blocks:
10.32.254.9, from 10.32.254.9, 00:02:03 ago, via Vlan267
Route metric is 3072, traffic share count is 1
Total delay is 20 microseconds, minimum bandwidth is 1000000 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1
* 10.32.254.5, from 10.32.254.5, 00:02:03 ago, via Vlan266
HERE IS WHAT THE REMOTE SIDE LOOKS LIKE
host ip 172.16.4.4 255.255.252.0
interface Vlan5
description *** REMOTE_Data_Vlan ***
no shutdown
no ip redirects
ip address 172.16.6.176/22
ip router eigrp 100
ip passive-interface eigrp 100
hsrp 5
authentication text REDACTED
preempt
priority 200
ip 172.16.4.1
LOCAL# show ip route 10.32.253.2
IP Route Table for VRF "default"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
Route not found
Here is his FULL routing table, it looks like he can't see all of my routes
show ip route
10.32.100.0/28, ubest/mbest: 1/0, attached
*via 10.32.100.12, Vlan970, [0/0], 5d02h, direct
10.32.100.12/32, ubest/mbest: 1/0, attached
*via 10.32.100.12, Vlan970, [0/0], 5d02h, local
10.32.100.14/32, ubest/mbest: 1/0, attached
*via 10.32.100.14, Vlan970, [0/0], 5d02h, hsrp
10.32.200.248/29, ubest/mbest: 1/0, attached
*via 10.32.200.252, Vlan920, [0/0], 5d02h, direct
10.32.200.252/32, ubest/mbest: 1/0, attached
*via 10.32.200.252, Vlan920, [0/0], 5d02h, local
10.32.200.254/32, ubest/mbest: 1/0, attached
*via 10.32.200.254, Vlan920, [0/0], 5d02h, hsrp
10.32.254.0/30, ubest/mbest: 1/0
*via 10.32.254.10, Vlan267, [90/130816], 00:00:19, eigrp-100, internal
10.32.254.4/30, ubest/mbest: 4/0
*via 10.32.254.10, Vlan267, [90/3072], 00:00:19, eigrp-100, internal
*via 10.255.0.12, Vlan999, [90/3072], 00:00:29, eigrp-100, internal
*via 10.255.1.220, Vlan255, [90/3072], 00:00:29, eigrp-100, internal
*via 10.255.254.10, Vlan254, [90/3072], 00:00:29, eigrp-100, internal
10.32.254.8/30, ubest/mbest: 1/0, attached
*via 10.32.254.9, Vlan267, [0/0], 00:00:26, direct
10.32.254.9/32, ubest/mbest: 1/0, attached
*via 10.32.254.9, Vlan267, [0/0], 00:00:26, local
10.100.4.0/22, ubest/mbest: 1/0, attached
*via 10.100.7.252, Vlan700, [0/0], 5d02h, direct
10.100.7.252/32, ubest/mbest: 1/0, attached
*via 10.100.7.252, Vlan700, [0/0], 5d02h, local
10.100.7.254/32, ubest/mbest: 1/0, attached
*via 10.100.7.254, Vlan700, [0/0], 5d02h, hsrp
10.101.0.0/21, ubest/mbest: 1/0, attached
*via 10.101.7.252, Vlan705, [0/0], 5d02h, direct
10.101.7.252/32, ubest/mbest: 1/0, attached
*via 10.101.7.252, Vlan705, [0/0], 5d02h, local
10.101.7.254/32, ubest/mbest: 1/0, attached
*via 10.101.7.254, Vlan705, [0/0], 5d02h, hsrp
10.218.3.0/24, ubest/mbest: 1/0, attached
*via 10.218.3.252, Vlan310, [0/0], 5d02h, direct
10.218.3.252/32, ubest/mbest: 1/0, attached
*via 10.218.3.252, Vlan310, [0/0], 5d02h, local
10.218.3.254/32, ubest/mbest: 1/0, attached
*via 10.218.3.254, Vlan310, [0/0], 5d02h, hsrp
10.218.100.0/24, ubest/mbest: 1/0, attached
*via 10.218.100.252, Vlan252, [0/0], 5d02h, direct
10.218.100.252/32, ubest/mbest: 1/0, attached
*via 10.218.100.252, Vlan252, [0/0], 5d02h, local
10.218.100.254/32, ubest/mbest: 1/0, attached
*via 10.218.100.254, Vlan252, [0/0], 5d02h, hsrp
10.218.101.0/24, ubest/mbest: 1/0, attached
*via 10.218.101.252, Vlan800, [0/0], 5d02h, direct
10.218.101.252/32, ubest/mbest: 1/0, attached
*via 10.218.101.252, Vlan800, [0/0], 5d02h, local
10.218.101.254/32, ubest/mbest: 1/0, attached
*via 10.218.101.254, Vlan800, [0/0], 5d02h, hsrp
10.235.200.0/26, ubest/mbest: 1/0, attached
*via 10.235.200.61, Vlan802, [0/0], 5d02h, direct
10.235.200.61/32, ubest/mbest: 1/0, attached
*via 10.235.200.61, Vlan802, [0/0], 5d02h, local
10.235.200.62/32, ubest/mbest: 1/0, attached
*via 10.235.200.62, Vlan802, [0/0], 5d02h, hsrp
10.235.201.0/26, ubest/mbest: 1/0, attached
*via 10.235.201.61, Vlan803, [0/0], 5d02h, direct
10.235.201.61/32, ubest/mbest: 1/0, attached
*via 10.235.201.61, Vlan803, [0/0], 5d02h, local
10.235.201.62/32, ubest/mbest: 1/0, attached
*via 10.235.201.62, Vlan803, [0/0], 5d02h, hsrp
10.235.202.0/28, ubest/mbest: 1/0, attached
*via 10.235.202.13, Vlan804, [0/0], 5d02h, direct
10.235.202.13/32, ubest/mbest: 1/0, attached
*via 10.235.202.13, Vlan804, [0/0], 5d02h, local
10.235.202.14/32, ubest/mbest: 1/0, attached
*via 10.235.202.14, Vlan804, [0/0], 5d02h, hsrp
10.235.203.0/28, ubest/mbest: 1/0, attached
*via 10.235.203.13, Vlan805, [0/0], 5d02h, direct
10.235.203.13/32, ubest/mbest: 1/0, attached
*via 10.235.203.13, Vlan805, [0/0], 5d02h, local
10.235.203.14/32, ubest/mbest: 1/0, attached
*via 10.235.203.14, Vlan805, [0/0], 5d02h, hsrp
10.235.204.0/27, ubest/mbest: 1/0, attached
*via 10.235.204.29, Vlan806, [0/0], 5d02h, direct
10.235.204.29/32, ubest/mbest: 1/0, attached
*via 10.235.204.29, Vlan806, [0/0], 5d02h, local
10.235.204.30/32, ubest/mbest: 1/0, attached
*via 10.235.204.30, Vlan806, [0/0], 5d02h, hsrp
10.235.210.0/28, ubest/mbest: 3/0
*via 10.255.0.12, Vlan999, [90/3072], 4d03h, eigrp-100, internal
*via 10.255.1.220, Vlan255, [90/3072], 4d03h, eigrp-100, internal
*via 10.255.254.10, Vlan254, [90/3072], 4d03h, eigrp-100, internal
10.252.0.16/28, ubest/mbest: 1/0, attached
*via 10.252.0.29, Vlan982, [0/0], 5d02h, direct
10.252.0.29/32, ubest/mbest: 1/0, attached
*via 10.252.0.29, Vlan982, [0/0], 5d02h, local
10.252.0.32/28, ubest/mbest: 1/0, attached
*via 10.252.0.44, Vlan979, [0/0], 5d02h, direct
10.252.0.44/32, ubest/mbest: 1/0, attached
*via 10.252.0.44, Vlan979, [0/0], 5d02h, local
10.252.0.46/32, ubest/mbest: 1/0, attached
*via 10.252.0.46, Vlan979, [0/0], 5d02h, hsrp
10.253.10.0/28, ubest/mbest: 1/0, attached
*via 10.253.10.12, Vlan500, [0/0], 5d02h, direct
10.253.10.12/32, ubest/mbest: 1/0, attached
*via 10.253.10.12, Vlan500, [0/0], 5d02h, local
10.253.10.14/32, ubest/mbest: 1/0, attached
*via 10.253.10.14, Vlan500, [0/0], 5d02h, hsrp
10.253.10.16/28, ubest/mbest: 1/0, attached
*via 10.253.10.28, Vlan503, [0/0], 5d02h, direct
10.253.10.28/32, ubest/mbest: 1/0, attached
*via 10.253.10.28, Vlan503, [0/0], 5d02h, local
10.253.10.30/32, ubest/mbest: 1/0, attached
*via 10.253.10.30, Vlan503, [0/0], 5d02h, hsrp
10.253.10.64/26, ubest/mbest: 1/0, attached
*via 10.253.10.124, Vlan501, [0/0], 5d02h, direct
10.253.10.124/32, ubest/mbest: 1/0, attached
*via 10.253.10.124, Vlan501, [0/0], 5d02h, local
10.253.10.126/32, ubest/mbest: 1/0, attached
*via 10.253.10.126, Vlan501, [0/0], 5d02h, hsrp
10.253.10.128/26, ubest/mbest: 1/0, attached
*via 10.253.10.188, Vlan502, [0/0], 5d02h, direct
10.253.10.188/32, ubest/mbest: 1/0, attached
*via 10.253.10.188, Vlan502, [0/0], 5d02h, local
10.253.10.190/32, ubest/mbest: 1/0, attached
*via 10.253.10.190, Vlan502, [0/0], 5d02h, hsrp
10.253.11.0/28, ubest/mbest: 1/0, attached
*via 10.253.11.13, Vlan599, [0/0], 5d02h, direct
10.253.11.13/32, ubest/mbest: 1/0, attached
*via 10.253.11.13, Vlan599, [0/0], 5d02h, local
10.253.11.14/32, ubest/mbest: 1/0, attached
*via 10.253.11.14, Vlan599, [0/0], 5d02h, hsrp
10.253.12.0/24, ubest/mbest: 1/0, attached
*via 10.253.12.252, Vlan504, [0/0], 5d02h, direct
10.253.12.252/32, ubest/mbest: 1/0, attached
*via 10.253.12.252, Vlan504, [0/0], 5d02h, local
10.253.12.254/32, ubest/mbest: 1/0, attached
*via 10.253.12.254, Vlan504, [0/0], 5d02h, hsrp
10.253.15.0/24, ubest/mbest: 1/0, attached
*via 10.253.15.254, Vlan505, [0/0], 5d02h, direct
10.253.15.254/32, ubest/mbest: 1/0, attached
*via 10.253.15.254, Vlan505, [0/0], 5d02h, local
10.254.0.0/24, ubest/mbest: 1/0, attached
*via 10.254.0.252, Vlan200, [0/0], 5d02h, direct
10.254.0.252/32, ubest/mbest: 1/0, attached
*via 10.254.0.252, Vlan200, [0/0], 5d02h, local
10.254.0.254/32, ubest/mbest: 1/0, attached
*via 10.254.0.254, Vlan200, [0/0], 5d02h, hsrp
10.254.2.0/24, ubest/mbest: 1/0, attached
*via 10.254.2.252, Vlan250, [0/0], 5d02h, direct
10.254.2.252/32, ubest/mbest: 1/0, attached
*via 10.254.2.252, Vlan250, [0/0], 5d02h, local
10.254.2.254/32, ubest/mbest: 1/0, attached
*via 10.254.2.254, Vlan250, [0/0], 5d02h, hsrp
10.254.4.0/23, ubest/mbest: 1/0, attached
*via 10.254.5.252, Vlan201, [0/0], 5d02h, direct
10.254.5.252/32, ubest/mbest: 1/0, attached
*via 10.254.5.252, Vlan201, [0/0], 5d02h, local
10.254.5.254/32, ubest/mbest: 1/0, attached
*via 10.254.5.254, Vlan201, [0/0], 5d02h, hsrp
10.254.6.0/23, ubest/mbest: 1/0, attached
*via 10.254.7.252, Vlan202, [0/0], 5d02h, direct
10.254.7.252/32, ubest/mbest: 1/0, attached
*via 10.254.7.252, Vlan202, [0/0], 5d02h, local
10.254.7.254/32, ubest/mbest: 1/0, attached
*via 10.254.7.254, Vlan202, [0/0], 5d02h, hsrp
10.254.8.0/23, ubest/mbest: 1/0, attached
*via 10.254.9.252, Vlan203, [0/0], 5d02h, direct
10.254.9.252/32, ubest/mbest: 1/0, attached
*via 10.254.9.252, Vlan203, [0/0], 5d02h, local
10.254.9.254/32, ubest/mbest: 1/0, attached
*via 10.254.9.254, Vlan203, [0/0], 5d02h, hsrp
10.254.10.0/23, ubest/mbest: 1/0, attached
*via 10.254.11.252, Vlan204, [0/0], 5d02h, direct
10.254.11.252/32, ubest/mbest: 1/0, attached
*via 10.254.11.252, Vlan204, [0/0], 5d02h, local
10.254.11.254/32, ubest/mbest: 1/0, attached
*via 10.254.11.254, Vlan204, [0/0], 5d02h, hsrp
10.254.12.0/23, ubest/mbest: 1/0, attached
*via 10.254.13.252, Vlan205, [0/0], 5d02h, direct
10.254.13.252/32, ubest/mbest: 1/0, attached
*via 10.254.13.252, Vlan205, [0/0], 5d02h, local
10.254.13.254/32, ubest/mbest: 1/0, attached
*via 10.254.13.254, Vlan205, [0/0], 5d02h, hsrp
10.254.14.0/23, ubest/mbest: 1/0, attached
*via 10.254.15.252, Vlan206, [0/0], 5d02h, direct
10.254.15.252/32, ubest/mbest: 1/0, attached
*via 10.254.15.252, Vlan206, [0/0], 5d02h, local
10.254.15.254/32, ubest/mbest: 1/0, attached
*via 10.254.15.254, Vlan206, [0/0], 5d02h, hsrp
10.254.16.0/23, ubest/mbest: 1/0, attached
*via 10.254.17.252, Vlan207, [0/0], 5d02h, direct
10.254.17.252/32, ubest/mbest: 1/0, attached
*via 10.254.17.252, Vlan207, [0/0], 5d02h, local
10.254.17.254/32, ubest/mbest: 1/0, attached
*via 10.254.17.254, Vlan207, [0/0], 5d02h, hsrp
10.254.20.0/23, ubest/mbest: 1/0, attached
*via 10.254.21.252, Vlan209, [0/0], 5d02h, direct
10.254.21.252/32, ubest/mbest: 1/0, attached
*via 10.254.21.252, Vlan209, [0/0], 5d02h, local
10.254.21.254/32, ubest/mbest: 1/0, attached
*via 10.254.21.254, Vlan209, [0/0], 5d02h, hsrp
10.254.22.0/23, ubest/mbest: 1/0, attached
*via 10.254.23.252, Vlan210, [0/0], 5d02h, direct
10.254.23.252/32, ubest/mbest: 1/0, attached
*via 10.254.23.252, Vlan210, [0/0], 5d02h, local
10.254.23.254/32, ubest/mbest: 1/0, attached
*via 10.254.23.254, Vlan210, [0/0], 5d02h, hsrp
10.254.24.0/23, ubest/mbest: 1/0, attached
*via 10.254.24.252, Vlan211, [0/0], 5d02h, direct
10.254.24.252/32, ubest/mbest: 1/0, attached
*via 10.254.24.252, Vlan211, [0/0], 5d02h, local
10.254.24.254/32, ubest/mbest: 1/0, attached
*via 10.254.24.254, Vlan211, [0/0], 5d02h, hsrp
10.255.0.0/28, ubest/mbest: 1/0, attached
*via 10.255.0.13, Vlan999, [0/0], 5d02h, direct
10.255.0.13/32, ubest/mbest: 1/0, attached
*via 10.255.0.13, Vlan999, [0/0], 5d02h, local
10.255.0.14/32, ubest/mbest: 1/0, attached
*via 10.255.0.14, Vlan999, [0/0], 5d02h, hsrp
10.255.0.16/28, ubest/mbest: 1/0, attached
*via 10.255.0.29, Vlan994, [0/0], 5d02h, direct
10.255.0.29/32, ubest/mbest: 1/0, attached
*via 10.255.0.29, Vlan994, [0/0], 5d02h, local
10.255.0.30/32, ubest/mbest: 1/0, attached
*via 10.255.0.30, Vlan994, [0/0], 5d02h, hsrp
10.255.0.80/28, ubest/mbest: 1/0, attached
*via 10.255.0.93, Vlan998, [0/0], 5d02h, direct
10.255.0.93/32, ubest/mbest: 1/0, attached
*via 10.255.0.93, Vlan998, [0/0], 5d02h, local
10.255.0.94/32, ubest/mbest: 1/0, attached
*via 10.255.0.94, Vlan998, [0/0], 5d02h, hsrp
10.255.0.112/28, ubest/mbest: 1/0, attached
*via 10.255.0.125, Vlan989, [0/0], 5d02h, direct
10.255.0.125/32, ubest/mbest: 1/0, attached
*via 10.255.0.125, Vlan989, [0/0], 5d02h, local
10.255.0.126/32, ubest/mbest: 1/0, attached
*via 10.255.0.126, Vlan989, [0/0], 5d02h, hsrp
10.255.0.176/28, ubest/mbest: 1/0, attached
*via 10.255.0.188, Vlan985, [0/0], 5d02h, direct
10.255.0.188/32, ubest/mbest: 1/0, attached
*via 10.255.0.188, Vlan985, [0/0], 5d02h, local
10.255.0.190/32, ubest/mbest: 1/0, attached
*via 10.255.0.190, Vlan985, [0/0], 5d02h, hsrp
10.255.0.192/26, ubest/mbest: 1/0, attached
*via 10.255.0.252, Vlan984, [0/0], 5d02h, direct
10.255.0.252/32, ubest/mbest: 1/0, attached
*via 10.255.0.252, Vlan984, [0/0], 5d02h, local
10.255.0.254/32, ubest/mbest: 1/0, attached
*via 10.255.0.254, Vlan984, [0/0], 5d02h, hsrp
10.255.1.0/24, ubest/mbest: 1/0, attached
*via 10.255.1.221, Vlan255, [0/0], 5d02h, direct
10.255.1.221/32, ubest/mbest: 1/0, attached
*via 10.255.1.221, Vlan255, [0/0], 5d02h, local
10.255.1.254/32, ubest/mbest: 1/0, attached
*via 10.255.1.254, Vlan255, [0/0], 5d02h, hsrp
10.255.254.0/28, ubest/mbest: 1/0, attached
*via 10.255.254.11, Vlan254, [0/0], 5d02h, direct
10.255.254.11/32, ubest/mbest: 1/0, attached
*via 10.255.254.11, Vlan254, [0/0], 5d02h, local
172.16.4.0/22, ubest/mbest: 1/0, attached
*via 172.16.6.176, Vlan5, [0/0], 5d02h, direct
172.16.4.1/32, ubest/mbest: 1/0, attached
*via 172.16.4.1, Vlan5, [0/0], 5d02h, hsrp
172.16.6.176/32, ubest/mbest: 1/0, attached
*via 172.16.6.176, Vlan5, [0/0], 5d02h, local
172.18.4.0/22, ubest/mbest: 1/0, attached
*via 172.18.7.252, Vlan2, [0/0], 5d02h, direct
172.18.4.1/32, ubest/mbest: 1/0, attached
*via 172.18.4.1, Vlan2, [0/0], 5d02h, hsrp
172.18.7.252/32, ubest/mbest: 1/0, attached
*via 172.18.7.252, Vlan2, [0/0], 5d02h, local
172.30.4.0/22, ubest/mbest: 1/0, attached
*via 172.30.7.252, Vlan3, [0/0], 5d02h, direct
172.30.4.1/32, ubest/mbest: 1/0, attached
*via 172.30.4.1, Vlan3, [0/0], 5d02h, hsrp
172.30.7.252/32, ubest/mbest: 1/0, attached
*via 172.30.7.252, Vlan3, [0/0], 5d02h, local
172.30.9.0/24, ubest/mbest: 1/0, attached
*via 172.30.9.252, Vlan102, [0/0], 5d02h, direct
172.30.9.1/32, ubest/mbest: 1/0, attached
*via 172.30.9.1, Vlan102, [0/0], 5d02h, hsrp
172.30.9.252/32, ubest/mbest: 1/0, attached
*via 172.30.9.252, Vlan102, [0/0], 5d02h, local
172.32.4.0/22, ubest/mbest: 1/0, attached
*via 172.32.7.252, Vlan4, [0/0], 5d02h, direct
172.32.4.1/32, ubest/mbest: 1/0, attached
*via 172.32.4.1, Vlan4, [0/0], 5d02h, hsrp
172.32.7.252/32, ubest/mbest: 1/0, attached
*via 172.32.7.252, Vlan4, [0/0], 5d02h, local
WHY CAN'T HE SEE MY 10.32.253.2 ??????
Hello
at first glance it looks like you’ve entered the network addresses of the subnets and not the host address ranges in the eigrp process
it needs to be either - example
10.32.253.0 0.0.0.7 = /28
or
10.32.253.1 0.0.0.0 = specific  host /32
Kind Regards
Paul
lowfell
Level 3
Level 3
Hello all. Could it be the "passive-interface default" command that is stopping him seeing my networks and if I used.
#no Passive-interface on the interface I want him to see then he should have visibility?
Hello
or
Kind Regards
Paul
Ok, to fix this we did this.
This was the existing.
router eigrp 100
The interface address was
THIS DID NOT WORK
TO fix it we changed the EIGRP to
router eigrp 100
network 10.32.253.1 0.0.0.0
and Hey presto! everything started working
Thanks for your help Paul.
Thanks again Paul
