WIC-1B-S/T LED OK
CSCO11544512
What does the led OK for WIC-1B-S/T mean ? On my T0 connexion, it is sometimes green, at other times no light at all.
Is it a configuration mistake or a problem with the line ?
Anuloma -
acampbell
Looking at this book
http://www.cisco.com/en/US/docs/routers/access/interfaces/ic/hardware/installation/guide/isdn_wic.pdf
Page 12
Step 6
Check that the OK LED goes on, which indicates that the ISDN port has established a connection with
the central office switch.
Check/replace cable -- or it could be a TELCO issue
Alex
Regards, Alex. Please rate useful posts.
My Telco (France Telecom) says the line is good.
Here is the output from debug bri :
Apr  6 14:42:31: BRI0/0: In state F7, Received code Level detected
Apr  6 14:42:31: BRI0/0 : dchan tx fifo flush, actual_time = 0
Apr  6 14:42:31: BRI0/0 : changing state to F8
Apr  6 14:42:31: BRI0/0 : Sending MPH-ERROR Indication reporting error to layer2
Apr  6 14:42:31: BRI0/0: In state F8, Received code Deactivate request
Apr  6 14:42:31: BRI0/0 : stop and reset timer t3
Apr  6 14:42:31: BRI0/0 : changing state to F3
Apr  6 14:42:31: BRI0/0 : Starting layer 1 T4
Apr  6 14:42:31: BRI0/0 : T4 expired
Apr  6 14:42:31: BRI0/0 : Sending PH-DEACTIVATE to layer2
Apr  6 14:42:31: BRI0/0 : changing state to F3BRI: disable channel B1
BRI: disable channel B2
bel-GTW-RN#
Apr  6 14:42:31: BRI0/0: In state F3, Transmitting code Deactivate indication up
stream
Apr  6 14:42:31: BRI0/0: In state F3, Received code Deactivate indication downst
ream
Apr  6 14:42:31: BRI0/0 : do nothingBRI: disable channel B1
bel-GTW-RN#
Apr  6 14:42:42: BRI0/0: In state F3, Received code Level detected
Apr  6 14:42:42: BRI0/0 : changing state to F5
Apr  6 14:42:42: BRI0/0: In state F5, Received code Activate request downstream,
Info 2 received
Apr  6 14:42:42: BRI0/0 : changing state to F6
Apr  6 14:42:42: BRI0/0: In state F6, Received code Activation Indication with P
riority to 8, Info 4 received
Apr  6 14:42:42: BRI0/0 : Sending PH-Activate to the layer 2
Apr  6 14:42:42: BRI0/0 : changing state to F7
Apr  6 14:42:42: BRI0/0 : dchan tx fifo flush, actual_time = 0
Apr  6 14:42:42: BRI0/0 : stop and reset timer t3
Apr  6 14:42:42: BRI0/0: In state F7, Transmitting code Activation Request, set
Priority to 8
Apr  6 14:42:42: BRI0/0 : Sending MPH-ERROR Indication reporting recovery from e
rror to layer2
Apr  6 14:42:42: dchan tx start
Apr  6 14:42:42: dchan tx intr
bel-GTW-RN#
Apr  6 14:42:42: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0, TEI 77 changed t
o up
bel-GTW-RN#
Apr  6 14:42:45: dchan tx start
Apr  6 14:42:45: dchan tx intr
bel-GTW-RN#
Apr  6 14:42:52: dchan tx start
Apr  6 14:42:52: dchan tx intr
According to google searches this is almost certainly a TELCO issue.
The only other thing I can think of is are using the correct
ISDN switch type.
For france there seems to be a couple
basic-net3 and vn3
Alex
Thanks !
I'll call our Telco.
I think the ISDN switch type is good since the same configuration is used in other center of the same company.
