08-07-2013 05:14 AM - edited 03-07-2019 02:48 PM
Is SPA-5X1GE-V2 compatible with ASR1002-X Router?
As per the Data Sheet it is compatible with Cisco ASR 1000 Series Router. I have verified it in ASR1002 and its working.
But when I insert the SPA-5X1GE-V2 card in ASR1002-X Router, the card is not getting detected.
Thanks in advance.
01-02-2019 08:43 AM
Hello!
Did you find the solution to this problem? I am having the exactly same problem.
Best Regards,
11-09-2020 11:31 AM
Has anyone found a resolution to this issue? We are experiencing a similar problem.
Many thanks
Chris
11-09-2020 11:52 PM
- Check the logs when the card is being inserted , check if any additional (error) info's can be found.
M.
