Cisco Community Designated VIP Class of 2020
1193
Will ws-sup32-ge-3b supports IOS w/o MSFC ?
Hi Friends ,
I have a sup 32 (WS-SUP32-GE-3B) i dont find any msfc card ? is there any command to check if msfc is present or offline/online ? Also will i be able to upgrade IOS for this sup with out MSFC ?
Kamal
1 ACCEPTED SOLUTION
Hi Kamal,
Sup32 (WS-SUP32-GE-3B) has MSFC2A.
WS-SUP32-GE-3B = Supervisor Engine 32, PFC3B, MSFC2A.
You can check this detail by issuing show module
Cat6k#Show module
Mod Ports Card Type                              Model              Serial No.
  1    5  Communication Media Module             WS-SVC-CMM         SAD10050574
  3   48  48 port 10/100 mb RJ45                 WS-X6348-RJ-45     SAD04220GAR
  4   48  48 port 10/100 mb RJ45                 WS-X6348-RJ-45     SAD0425012K
  5    9  Supervisor Engine 32 8GE (Active)      WS-SUP32-GE-3B     SAL1011G62Z
  6    4  SLB Application Processor Complex      WS-X6066-SLB-APC   SAD08330ELX
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0016.c738.2d0e to 0016.c738.2d17   2.8   12.3(8)XY7,  12.3(8)XY7,  Ok
  3  0001.9717.c320 to 0001.9717.c34f   1.1   5.3(1)       8.5(0.46)RFW Ok
  4  0001.9720.8a90 to 0001.9720.8abf   1.1   5.3(1)       8.5(0.46)RFW Ok
  5  0015.f9d4.21f0 to 0015.f9d4.21fb   4.2   12.2(18r)SX2 12.2(18)SXF4 Ok
  6  0011.93b3.d750 to 0011.93b3.d757   1.7                4.1(2)       Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  5  Policy Feature Card 3       WS-F6K-PFC3B       SAL1011G1VS  2.1    Ok
  5  Cat6k MSFC 2A daughterboard WS-F6K-MSFC2A      SAL1011G0BT  3.0    Ok
Under the Sub-Module section, find the feature card and the router card. In this example, the feature card and router card are:
WS-F6K-PFC3B = module is equipped with a PFC3B.
WS-F6K-MSFC2A = module is equipped with an MSFC2A.
2. will i be able to upgrade IOS for this sup with out MSFC?
Answer: CatOS is supported for layer 2 (switching) operations only. To be able to perform routing functions (e.g. Layer 3) operations, the switch must be run in hybrid mode. In this case, CatOS runs on the Switch Processor (SP) portion of the Supervisor, and IOS runs on the Route Processor (RP) also known as the MSFC
Without MSFC, you can run only CAT OS on the supervisor.
Refer:
How to Determine the Type of Supervisor Module That Is Installed in Catalyst 6500/6000 Series Switches
http://www.cisco.com/en/US/partner/products/hw/switches/ps700/products_tech_note09186a00801c0eb0.shtml#sup32
Understanding MSFC, PFC and DFC roles in Catalyst 6500 Series Switch
https://supportforums.cisco.com/docs/DOC-21377
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
4 REPLIES 4
Hi Kamal,
Cat6k#Show module
Refer:
Aru
Thanks for your input , Actually the msfc was not shown when i gave show module command ... It had some corrupt IOS .. now its fixed and its working fine....
Greetings, What changes you
Greetings,
What changes you have done on the switch, to enable MSFC2A card. I have also same issue , in show module output MSFC card is not showing
Greetings, I have the same
Greetings,
I have the same issue. When I do show module it does not show the MSFC 2A daughter card.
Is there are procedure to recover the MSFC 2A card. Below is the show module output
switch> (enable) sh module
Mod Slot Ports Module-Type               Model               Sub Status
1   1    48    10/100/1000BaseT Ethernet WS-X6148A-GE-45AF   yes ok
2   2    48    10/100/1000BaseT Ethernet WS-X6148A-GE-45AF   yes ok
3   3    48    10/100/1000BaseT Ethernet WS-X6148A-GE-45AF   yes ok
4   4    48    10/100/1000BaseT Ethernet WS-X6148A-GE-45AF   yes ok
5   5    9     1000BaseX Supervisor      WS-SUP32-GE-3B      yes ok
6   6    48    10/100/1000BaseT Ethernet WS-X6148A-GE-45AF   yes ok
7   7    48    10/100/1000BaseT Ethernet WS-X6148A-GE-45AF   yes ok
8   8    48    10/100/1000BaseT Ethernet WS-X6148A-GE-45AF   yes ok
9   9    48    10/100/1000BaseT Ethernet WS-X6148A-GE-45AF   yes ok
Mod Module-Name          Serial-Num
1                        SAL1127T8PZ
2                        SAL1114L0D8
3                        SAL1122Q9ZV
4                        SAL1135Z3YT
5                        SAL1113KCW6
6                        SAL1123QL5E
7                        SAL1114L0E6
8                        SAL1135Z3Z8
9                        SAD09420BKT
Mod MAC-Address(es)                        Hw     Fw         Sw
1   00-1c-58-5f-29-50 to 00-1c-58-5f-29-7f 2.3    8.4(1)     8.5(5)
2   00-1b-53-4f-10-20 to 00-1b-53-4f-10-4f 2.2    8.4(1)     8.5(5)
3   00-1b-d4-f1-bb-10 to 00-1b-d4-f1-bb-3f 2.2    8.4(1)     8.5(5)
4   00-1d-45-6d-a8-c0 to 00-1d-45-6d-a8-ef 2.3    8.4(1)     8.5(5)
5   00-1a-6d-1a-88-8e to 00-1a-6d-1a-88-8f 4.5    12.2       8.5(5)
    00-1a-6d-1a-88-84 to 00-1a-6d-1a-88-8f
    00-1a-e3-29-fc-00 to 00-1a-e3-29-ff-ff
6   00-1b-d5-71-c9-40 to 00-1b-d5-71-c9-6f 2.2    8.4(1)     8.5(5)
7   00-1b-54-7f-e7-90 to 00-1b-54-7f-e7-bf 2.2    8.4(1)     8.5(5)
8   00-1d-45-66-1f-90 to 00-1d-45-66-1f-bf 2.3    8.4(1)     8.5(5)
9   00-15-f9-40-57-f0 to 00-15-f9-40-58-1f 1.3    8.4(1)     8.5(5)
Mod Sub-Type                Sub-Model           Sub-Serial  Sub-Hw Sub-Sw
1   IEEE InlinePower Module WS-F6K-48-AF        SAL1127TJQB 2.3    8.5(1132)
2   IEEE InlinePower Module WS-F6K-48-AF        SAL1114KZ5V 2.3    8.5(1132)
3   IEEE InlinePower Module WS-F6K-48-AF        SAL1122QBMB 2.3    8.5(1132)
4   IEEE InlinePower Module WS-F6K-48-AF        SAL1135Z2ZU 2.3    8.5(1132)
5   L3 Switching Engine III WS-F6K-PFC3B        SAL1113KCSW 2.3
6   IEEE InlinePower Module WS-F6K-48-AF        SAL1122Q5HE 2.3    8.5(1132)
7   IEEE InlinePower Module WS-F6K-48-AF        SAL1114KVZG 2.3    8.5(1132)
8   IEEE InlinePower Module WS-F6K-48-AF        SAL1135Z308 2.3    8.5(1132)
9   IEEE InlinePower Module WS-F6K-GE48-AF      SAD09420CP3 1.2    8.5(1132).
Kindly do the needful.
Content for Community-Ad
