Wire rate vs non blocking switch
Jonn cos
Level 9
Level 9
Hi all, i am often confused by these 2 terms. Please help me to understand them
  • if a switch is wire rate, does that implicitly means its non blocking
  • or is it due to non blocking that the switch is wire rate ?
  • is it possible that a switch is wire rate but not non-blocking ?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
In the context of switch performance, generally a non-blocking switch's interior bus/fabric offers enough bandwidth that meets, or exceeds, the aggregate bandwidth of all its ports.  However, even if that's true, some switch architectures can block traffic due to head-of-line blocking, i.e. congestion on one port blocks another uncongested port or ports.  (NB: "modern" switch architectures usually don't have HoL blocking as a possible issue.)
Also even if a switch is non-blocking, regarding its interior bandwidth, wire-speed/line-rate requires the switch's frame/forwarding support full bandwidth with minium size frame/packets.
So to recap, non-blocking really means there's sufficient bandwidth, wire-speed/line-rate really means frame/packet forwarding supports full bandwidth regardless of frame/packet sizes.
