WLC Config Issues
up2014497
Hi I am having trouble configuring my WLC. This probably is something trivial. I have put the WLAN on my management network VLAN 10 (10.1.0.0/20). Its IP address is 10.1.0.5/20 and the Core1 IP address is 10.1.0.1/20 . The link connected to the WLC is a trunk link. Not sure why I am unable to ping or connect to the WLC. I hope the images are sufficient. ThanksScreenshot 2024-03-26 at 18.42.46.pngScreenshot 2024-03-26 at 18.42.55.pngScreenshot 2024-03-26 at 18.43.23.png
Martin L
Add switchport trunk native vlan 10 to switch ports GigabitEthernet1/0/1 and GigabitEthernet1/0/24 on L3 switch to get ping OK (PC to WLC)
In terms of GUI access to WLC, if u di not see web access, u may want to try different WLC model in PT
Regards, ML
**Please Rate All Helpful Responses **
Martin L
I think we had similar issue here last year; something with management vlan 1 or 0; please zip your PT file and add it here
Regards, ML
Here is the file thank you
Martin L
Regards, ML
