11-08-2010 01:00 AM - edited 03-06-2019 01:56 PM
Hi support NG,
as i am trying to save my system configuration either via "write mem" or via "copy running startup" i get the following error message:
%Error deleting ootdisk:cfg-650x-VSS-Nov--4-16-21-58.660-CEST-13 (No such device)[OK]
I am using following hardware/software:
WS-C6506-E
WS-X6748-GE-TX
WS-X6724-SFP
WS-SVC-FWM-1
VS-S720-10G
s72033-ipbasek9-vz.122-33.SXI2a.bin
650x-VSS#copy running-config startup-config
Destination filename [startup-config]?
Building configuration...
650x-VSS#
650x-VSS#wr mem
%Error deleting ootdisk:cfg-650x-VSS-Nov--4-15-53-43.110-CEST-12 (No such device)[OK]
650x-VSS#
Testing weather or not the startup config is modified:
650x-VSS#sh ru int gi2/1/41
interface GigabitEthernet2/1/41
description testing
switchport
switchport access vlan xxx
switchport mode access
end
650x-VSS(config)#int gi2/1/41
650x-VSS(config-if)#description BLA BLA BLA
650x-VSS(config-if)#end
650x-VSS#wr
%Error deleting ootdisk:cfg-650x-VSS-Nov--5-09-16-18.492-CEST-14 (No such device)[OK]
650x-VSS#
650x-VSS#
650x-VSS#sh startup-config | i BLA
650x-VSS#
switchport
end
Testing the Bootdisks:
650x-VSS#copy running-config slavesup-bootdisk:/2010.11.05-test.cfg
Destination filename [2010.11.05-CCAN-test.cfg]?
54880 bytes copied in 2.872 secs (19109 bytes/sec)
650x-VSS#copy running-config sup-bootdisk:/2010.11.05-test.cfg
54880 bytes copied in 2.572 secs (21337 bytes/sec)
Configuration:
archive
path sup-bootdisk:cfg-650x-VSS-$t
maximum 9
write-memory
650x-VSS#dir all
Directory of flexwan-fpd:/
0 dr-- <no size> <no date>
No space information available
Directory of system:/
2 -r-- 0 <no date> default-running-config
4 dr-x 0 <no date> memory
1 -rw- 54880 May 27 2010 21:33:48 +02:00 running-config
3 dr-x 0 <no date> vfiles
Directory of tmpsys:/
6 drw- 0 <no date> eem_lib_system
5 drw- 0 <no date> eem_lib_user
34 -rw- 0 <no date> eem_pnt_0
36 -rw- 0 <no date> eem_pnt_1
54 -rw- 0 <no date> eem_pnt_10
56 -rw- 0 <no date> eem_pnt_11
58 -rw- 0 <no date> eem_pnt_12
60 -rw- 0 <no date> eem_pnt_13
62 -rw- 0 <no date> eem_pnt_14
64 -rw- 0 <no date> eem_pnt_15
38 -rw- 0 <no date> eem_pnt_2
40 -rw- 0 <no date> eem_pnt_3
42 -rw- 0 <no date> eem_pnt_4
44 -rw- 0 <no date> eem_pnt_5
46 -rw- 0 <no date> eem_pnt_6
48 -rw- 0 <no date> eem_pnt_7
50 -rw- 0 <no date> eem_pnt_8
52 -rw- 0 <no date> eem_pnt_9
4 drw- 0 <no date> eem_policy
8 drw- 0 <no date> eem_pub
33 -rw- 0 <no date> eem_rpc_0
35 -rw- 0 <no date> eem_rpc_1
53 -rw- 0 <no date> eem_rpc_10
55 -rw- 0 <no date> eem_rpc_11
57 -rw- 0 <no date> eem_rpc_12
59 -rw- 0 <no date> eem_rpc_13
61 -rw- 0 <no date> eem_rpc_14
63 -rw- 0 <no date> eem_rpc_15
37 -rw- 0 <no date> eem_rpc_2
39 -rw- 0 <no date> eem_rpc_3
41 -rw- 0 <no date> eem_rpc_4
43 -rw- 0 <no date> eem_rpc_5
45 -rw- 0 <no date> eem_rpc_6
47 -rw- 0 <no date> eem_rpc_7
49 -rw- 0 <no date> eem_rpc_8
51 -rw- 0 <no date> eem_rpc_9
7 drw- 0 <no date> eem_temp
1 dr-x 0 <no date> lib
Directory of bootflash:/
1 -rw- 5607 Dec 8 2009 16:28:28 +01:00 startup-config.converted_vs-20091208-152654
2 -rw- 54880 Nov 5 2010 09:44:00 +01:00 2010.11.05config.txt
65536000 bytes total (65475256 bytes free)
Directory of sup-bootdisk:/
1 -rw- 106399240 Nov 5 2009 20:41:04 +01:00 s72033-ipbasek9-vz.122-33.SXI2a.bin
2 -rw- 33554432 Nov 5 2009 20:38:30 +01:00 sea_console.dat
3 -rw- 33554432 Nov 5 2009 23:11:52 +01:00 sea_log.dat
4 -rw- 56696548 Dec 15 2009 14:11:54 +01:00 s72033-ipbasek9-mz.122-33.SXI3.bin
5 -rw- 56645860 Dec 15 2009 16:30:00 +01:00 s72033-ipbasek9-mz.122-33.SXI2a.bin
6 -rw- 49356 Dec 21 2009 14:16:54 +01:00 cfg-650x-VSS-Dec-21-14-16-54.240-CEST-0
7 -rw- 49356 Dec 21 2009 14:16:56 +01:00 cfg-650x-VSS-Dec-21-14-16-55.624-CEST-0
8 -rw- 49356 Dec 21 2009 14:27:52 +01:00 cfg-650x-VSS-Dec-21-14-27-53.264-CEST-1
9 -rw- 49356 Dec 21 2009 14:27:54 +01:00 cfg-650x-VSS-Dec-21-14-27-54.488-CEST-1
10 -rw- 268215 Dec 21 2009 14:29:50 +01:00 debuginfo_20091221-142948-CEST
11 -rw- 60035 Feb 15 2010 19:10:42 +01:00 cfg-650x-VSS-Feb-15-19-10-43.575-CEST-10
12 -rw- 60613 Feb 16 2010 15:48:06 +01:00 cfg-650x-VSS-Feb-16-15-48-06.354-CEST-20
13 -rw- 59489 Feb 15 2010 15:45:20 +01:00 cfg-650x-VSS-Feb-15-15-45-20.727-CEST-2
14 -rw- 59764 Feb 15 2010 16:07:54 +01:00 cfg-650x-VSS-Feb-15-16-07-54.851-CEST-3
15 -rw- 59765 Feb 15 2010 16:32:06 +01:00 cfg-650x-VSS-Feb-15-16-32-05.943-CEST-4
16 -rw- 60024 Feb 15 2010 16:37:32 +01:00 cfg-650x-VSS-Feb-15-16-37-32.463-CEST-5
17 -rw- 60207 Feb 15 2010 17:00:06 +01:00 cfg-650x-VSS-Feb-15-17-00-06.875-CEST-6
18 -rw- 60207 Feb 15 2010 17:07:14 +01:00 cfg-650x-VSS-Feb-15-17-07-15.311-CEST-7
19 -rw- 60207 Feb 15 2010 17:24:40 +01:00 cfg-650x-VSS-Feb-15-17-24-40.971-CEST-8
20 -rw- 60035 Feb 15 2010 19:06:04 +01:00 cfg-650x-VSS-Feb-15-19-06-04.943-CEST-9
21 -rw- 60823 Feb 16 2010 15:51:50 +01:00 cfg-650x-VSS-Feb-16-15-51-50.262-CEST-21
22 -rw- 60823 Feb 16 2010 15:52:12 +01:00 cfg-650x-VSS-Feb-16-15-52-13.278-CEST-22
23 -rw- 60823 Feb 16 2010 15:54:14 +01:00 cfg-650x-VSS-Feb-16-15-54-14.674-CEST-23
24 -rw- 61003 Feb 16 2010 17:29:14 +01:00 cfg-650x-VSS-Feb-16-17-29-13.494-CEST-24
25 -rw- 61003 Feb 16 2010 17:29:14 +01:00 cfg-650x-VSS-Feb-16-17-29-15.110-CEST-24
26 -rw- 61003 Feb 16 2010 18:00:14 +01:00 cfg-650x-VSS-Feb-16-18-00-15.146-CEST-25
27 -rw- 60643 Feb 16 2010 15:43:16 +01:00 cfg-650x-VSS-Feb-16-15-43-17.066-CEST-17
28 -rw- 60657 Feb 16 2010 15:43:44 +01:00 cfg-650x-VSS-Feb-16-15-43-45.290-CEST-18
29 -rw- 60616 Feb 16 2010 15:47:22 +01:00 cfg-650x-VSS-Feb-16-15-47-21.782-CEST-19
30 -rw- 61003 Feb 16 2010 18:00:14 +01:00 cfg-650x-VSS-Feb-16-18-00-13.562-CEST-25
31 -rw- 54880 Nov 4 2010 14:33:38 +01:00 cfg-650x-VSS-Nov--4-14-33-37.816-CEST-9
32 -rw- 54682 Jun 24 2010 10:58:34 +02:00 cfg-650x-VSS-Jun-24-10-58-34.590-CEST-0
33 -rw- 54880 Nov 4 2010 15:12:08 +01:00 cfg-650x-VSS-Nov--4-15-12-08.124-CEST-10
34 -rw- 54690 Jul 27 2010 10:10:56 +02:00 cfg-650x-VSS-Jul-27-10-10-57.192-CEST-1
35 -rw- 54880 Nov 4 2010 15:12:30 +01:00 cfg-650x-VSS-Nov--4-15-12-30.820-CEST-11
36 -rw- 54890 Aug 6 2010 15:25:04 +02:00 cfg-650x-VSS-Aug--6-15-25-03.781-CEST-2
37 -rw- 54880 Nov 4 2010 15:53:42 +01:00 cfg-650x-VSS-Nov--4-15-53-43.110-CEST-12
38 -rw- 54889 Sep 9 2010 16:22:06 +02:00 cfg-650x-VSS-Sep--9-16-22-05.974-CEST-3
39 -rw- 54880 Nov 4 2010 16:21:58 +01:00 cfg-650x-VSS-Nov--4-16-21-58.660-CEST-13
40 -rw- 54895 Oct 1 2010 11:22:18 +02:00 cfg-650x-VSS-Oct--1-11-22-17.805-CEST-4
41 -rw- 54880 Nov 5 2010 09:16:18 +01:00 cfg-650x-VSS-Nov--5-09-16-18.492-CEST-14
42 -rw- 54866 Oct 6 2010 13:06:16 +02:00 cfg-650x-VSS-Oct--6-13-06-16.209-CEST-5
43 -rw- 54880 Nov 5 2010 09:33:42 +01:00 cfg-650x-VSS-Nov--5-09-33-42.404-CEST-15
44 -rw- 54866 Oct 6 2010 13:06:44 +02:00 cfg-650x-VSS-Oct--6-13-06-44.657-CEST-6
45 -rw- 54880 Nov 5 2010 09:38:00 +01:00 cfg-650x-VSS-Nov--5-09-38-00.801-CEST-16
46 -rw- 54914 Nov 1 2010 15:52:02 +01:00 cfg-650x-VSS-Nov--1-15-52-02.473-CEST-7
47 -rw- 54880 Nov 5 2010 09:40:18 +01:00 cfg-650x-VSS-Nov--5-09-40-17.653-CEST-17
48 -rw- 54880 Nov 4 2010 14:07:30 +01:00 cfg-650x-VSS-Nov--4-14-07-30.335-CEST-8
49 -rw- 54880 Nov 5 2010 09:40:46 +01:00 cfg-650x-VSS-Nov--5-09-40-45.417-CEST-18
50 -rw- 54880 Nov 5 2010 11:30:08 +01:00 cfg-650x-VSS-Nov--5-11-30-07.789-CEST-19
51 -rw- 54880 Nov 5 2010 13:19:04 +01:00 cfg-650x-VSS-Nov--5-13-19-05.229-CEST-20
52 -rw- 54880 Nov 5 2010 13:20:34 +01:00 cfg-650x-VSS-Nov--5-13-20-33.777-CEST-21
53 -rw- 54880 Nov 5 2010 13:21:12 +01:00 cfg-650x-VSS-Nov--5-13-21-12.365-CEST-22
54 -rw- 54880 Nov 5 2010 09:16:16 +01:00 cfg-650x-VSS-Nov--5-09-16-16.468-CEST-14
55 -rw- 54880 Nov 5 2010 09:33:40 +01:00 cfg-650x-VSS-Nov--5-09-33-40.964-CEST-15
56 -rw- 54880 Nov 5 2010 09:37:58 +01:00 cfg-650x-VSS-Nov--5-09-37-59.257-CEST-16
57 -rw- 54880 Nov 5 2010 09:40:16 +01:00 cfg-650x-VSS-Nov--5-09-40-16.725-CEST-17
58 -rw- 54880 Nov 5 2010 09:40:44 +01:00 cfg-650x-VSS-Nov--5-09-40-43.777-CEST-18
59 -rw- 54880 Nov 5 2010 11:30:06 +01:00 cfg-650x-VSS-Nov--5-11-30-06.341-CEST-19
60 -rw- 54880 Nov 5 2010 13:19:02 +01:00 cfg-650x-VSS-Nov--5-13-19-03.113-CEST-20
61 -rw- 54880 Nov 5 2010 13:20:32 +01:00 cfg-650x-VSS-Nov--5-13-20-31.933-CEST-21
62 -rw- 54880 Nov 5 2010 13:21:10 +01:00 cfg-650x-VSS-Nov--5-13-21-10.665-CEST-22
1024557056 bytes total (733724672 bytes free)
Directory of sup-microcode:/
1 -r-- 21058078 <no date> DRACO2_MP
2 -r-- 9319946 <no date> CHEVYS-LC
3 -r-- 11112818 <no date> C2LC
4 -r-- 333594 <no date> LCP_LX10100
5 -r-- 303528 <no date> LCP_LX1000
6 -r-- 325668 <no date> LCP_AX1000
7 -r-- 376712 <no date> LCP_AX10100
8 -r-- 366478 <no date> LCP_CPFAB
9 -r-- 746366 <no date> LCP_CPGBIT
10 -r-- 483374 <no date> LCP_CP10G
11 -r-- 809054 <no date> LCP_CPMBIT2
12 -r-- 894782 <no date> LCP_CPMBIT
13 -r-- 1267502 <no date> LCP_CPXBIT
14 -r-- 65318 <no date> LCP_ABOOT
15 -r-- 60490 <no date> LCP_BOOT
47523708 bytes total (0 bytes free)
Directory of const_nvram:/
1 -rw- 2476 <no date> vlan.dat
129004 bytes total (126528 bytes free)
Directory of slavenvram:/
1918 -rw- 54880 <no date> startup-config
1919 ---- 96 <no date> private-config
1920 -rw- 54880 <no date> underlying-config
1 ---- 502 <no date> persistent-data
2 ---- 0 <no date> rf_cold_starts
3 -rw- 0 <no date> ifIndex-table
1964024 bytes total (1905924 bytes free)
Directory of nvram:/
1 ---- 347 <no date> persistent-data
Directory of sw2-slot1-dfc-bootflash:/
No files in directory
15990784 bytes total (15990784 bytes free)
Directory of sw2-slot3-dfc-bootflash:/
Directory of slaveconst_nvram:/
Directory of slavesup-bootdisk:/
1 -rw- 106399240 Nov 5 2009 19:44:44 +01:00 s72033-ipbasek9-vz.122-33.SXI2a.bin
2 -rw- 33554432 Nov 5 2009 19:42:18 +01:00 sea_console.dat
3 -rw- 33554432 Nov 5 2009 22:13:56 +01:00 sea_log.dat
4 -rw- 13838 Dec 8 2009 17:04:48 +01:00 cfg-650x-VSS--Dec--8-16-04-48.243-0
5 -rw- 13838 Dec 8 2009 17:04:48 +01:00 cfg-650x-VSS--Dec--8-16-04-48.975-0
6 -rw- 13838 Dec 8 2009 17:05:50 +01:00 cfg-650x-VSS--Dec--8-16-05-49.795-1
7 -rw- 13838 Dec 8 2009 17:05:50 +01:00 cfg-650x-VSS--Dec--8-16-05-50.503-1
8 -rw- 13818 Dec 8 2009 17:09:12 +01:00 cfg-650x-VSS--Dec--8-16-09-12.847-2
9 -rw- 13818 Dec 8 2009 17:09:12 +01:00 cfg-650x-VSS--Dec--8-16-09-13.571-2
10 -rw- 13822 Dec 8 2009 17:12:00 +01:00 cfg-650x-VSS--Dec--8-16-12-00.387-3
11 -rw- 13822 Dec 8 2009 17:12:00 +01:00 cfg-650x-VSS--Dec--8-16-12-01.111-3
12 -rw- 13822 Dec 8 2009 17:14:12 +01:00 cfg-650x-VSS--Dec--8-16-14-13.223-4
13 -rw- 13822 Dec 8 2009 17:14:14 +01:00 cfg-650x-VSS--Dec--8-16-14-13.947-4
14 -rw- 14260 Dec 15 2009 15:49:30 +01:00 cfg-650x-VSS--Dec-15-14-49-30.082-9
15 -rw- 14102 Dec 15 2009 13:50:54 +01:00 cfg-650x-VSS--Dec-15-12-50-54.436-0
16 -rw- 56696548 Dec 15 2009 14:29:06 +01:00 s72033-ipbasek9-mz.122-33.SXI3.bin
17 -rw- 14145 Dec 15 2009 16:22:36 +01:00 cfg-650x-VSS--Dec-15-15-22-37.665-10
18 -rw- 14181 Dec 15 2009 14:37:00 +01:00 cfg-650x-VSS--Dec-15-13-36-59.907-1
19 -rw- 14145 Dec 15 2009 16:32:46 +01:00 cfg-650x-VSS--Dec-15-15-32-47.181-11
20 -rw- 14205 Dec 15 2009 15:19:00 +01:00 cfg-650x-VSS--Dec-15-14-19-00.462-2
21 -rw- 14185 Dec 15 2009 16:34:22 +01:00 cfg-650x-VSS--Dec-15-15-34-21.917-12
22 -rw- 14267 Dec 15 2009 15:23:52 +01:00 cfg-650x-VSS--Dec-15-14-23-53.694-3
23 -rw- 14324 Dec 15 2009 16:36:08 +01:00 cfg-650x-VSS--Dec-15-15-36-09.409-13
24 -rw- 14235 Dec 15 2009 15:24:50 +01:00 cfg-650x-VSS--Dec-15-14-24-49.662-4
25 -rw- 14301 Dec 15 2009 17:11:46 +01:00 cfg-650x-VSS--Dec-15-16-11-45.747-0
26 -rw- 14298 Dec 15 2009 15:26:54 +01:00 cfg-650x-VSS--Dec-15-14-26-55.270-5
27 -rw- 14173 Dec 15 2009 15:34:16 +01:00 cfg-650x-VSS--Dec-15-14-34-16.902-6
28 -rw- 14173 Dec 15 2009 15:34:16 +01:00 cfg-650x-VSS--Dec-15-14-34-17.618-6
29 -rw- 14145 Dec 15 2009 15:43:28 +01:00 cfg-650x-VSS--Dec-15-14-43-29.566-7
30 -rw- 14145 Dec 15 2009 15:43:30 +01:00 cfg-650x-VSS--Dec-15-14-43-30.318-7
31 -rw- 14260 Dec 15 2009 15:47:24 +01:00 cfg-650x-VSS--Dec-15-14-47-25.542-8
32 -rw- 14260 Dec 15 2009 15:47:26 +01:00 cfg-650x-VSS--Dec-15-14-47-26.286-8
33 -rw- 14260 Dec 15 2009 15:49:28 +01:00 cfg-650x-VSS--Dec-15-14-49-29.326-9
34 -rw- 14145 Dec 15 2009 16:22:36 +01:00 cfg-650x-VSS--Dec-15-15-22-36.897-10
35 -rw- 56645860 Dec 15 2009 16:32:20 +01:00 s72033-ipbasek9-mz.122-33.SXI2a.bin
36 -rw- 14145 Dec 15 2009 16:32:46 +01:00 cfg-650x-VSS--Dec-15-15-32-46.437-11
37 -rw- 14185 Dec 15 2009 16:34:20 +01:00 cfg-650x-VSS--Dec-15-15-34-21.157-12
38 -rw- 14324 Dec 15 2009 16:36:08 +01:00 cfg-650x-VSS--Dec-15-15-36-08.641-13
39 -rw- 14361 Dec 15 2009 16:59:58 +01:00 cfg-650x-VSS--Dec-15-15-59-59.381-14
40 -rw- 14301 Dec 15 2009 17:11:46 +01:00 cfg-650x-VSS--Dec-15-16-11-46.903-0
41 -rw- 14301 Dec 16 2009 16:35:18 +01:00 cfg-650x-VSS--Dec-16-15-35-18.519-0
42 -rw- 14301 Dec 16 2009 16:35:20 +01:00 cfg-650x-VSS--Dec-16-15-35-19.703-0
43 -rw- 15567 Dec 18 2009 14:37:04 +01:00 cfg-650x-VSS--Dec-18-13-37-03.711-9
44 -rw- 14795 Dec 17 2009 14:10:24 +01:00 cfg-650x-VSS--Dec-17-13-10-25.034-0
45 -rw- 14969 Dec 17 2009 14:14:14 +01:00 cfg-650x-VSS--Dec-17-13-14-13.658-1
46 -rw- 14969 Dec 17 2009 14:14:14 +01:00 cfg-650x-VSS--Dec-17-13-14-14.898-1
47 -rw- 15035 Dec 17 2009 15:14:16 +01:00 cfg-650x-VSS--Dec-17-14-14-16.238-2
48 -rw- 15035 Dec 17 2009 15:14:16 +01:00 cfg-650x-VSS--Dec-17-14-14-17.306-2
49 -rw- 14969 Dec 17 2009 15:18:00 +01:00 cfg-650x-VSS--Dec-17-14-17-59.918-3
50 -rw- 14969 Dec 17 2009 15:18:00 +01:00 cfg-650x-VSS--Dec-17-14-18-01.146-3
51 -rw- 14976 Dec 18 2009 09:41:20 +01:00 cfg-650x-VSS--Dec-18-08-41-21.130-4
52 -rw- 14976 Dec 18 2009 09:41:22 +01:00 cfg-650x-VSS--Dec-18-08-41-22.194-4
53 -rw- 14973 Dec 18 2009 09:42:30 +01:00 cfg-650x-VSS--Dec-18-08-42-31.070-5
54 -rw- 14973 Dec 18 2009 09:42:32 +01:00 cfg-650x-VSS--Dec-18-08-42-32.278-5
55 -rw- 15064 Dec 18 2009 09:52:12 +01:00 cfg-650x-VSS--Dec-18-08-52-13.285-6
56 -rw- 15064 Dec 18 2009 09:52:14 +01:00 cfg-650x-VSS--Dec-18-08-52-14.349-6
57 -rw- 15199 Dec 18 2009 11:50:50 +01:00 cfg-650x-VSS--Dec-18-10-50-49.873-7
58 -rw- 15199 Dec 18 2009 11:50:50 +01:00 cfg-650x-VSS--Dec-18-10-50-51.053-7
59 -rw- 15151 Dec 18 2009 11:55:52 +01:00 cfg-650x-VSS--Dec-18-10-55-53.205-8
60 -rw- 15151 Dec 18 2009 11:55:54 +01:00 cfg-650x-VSS--Dec-18-10-55-54.285-8
61 -rw- 15211 Dec 18 2009 12:31:02 +01:00 cfg-650x-VSS--Dec-18-11-31-02.921-9
62 -rw- 15212 Dec 18 2009 13:09:04 +01:00 cfg-650x-VSS--Dec-18-12-09-05.003-0
63 -rw- 15567 Dec 18 2009 14:37:32 +01:00 cfg-650x-VSS--Dec-18-13-37-31.663-10
64 -rw- 15344 Dec 18 2009 13:20:46 +01:00 cfg-650x-VSS--Dec-18-12-20-46.579-1
65 -rw- 15707 Dec 18 2009 14:55:34 +01:00 cfg-650x-VSS--Dec-18-13-55-34.971-11
66 -rw- 15373 Dec 18 2009 13:28:46 +01:00 cfg-650x-VSS--Dec-18-12-28-47.227-2
67 -rw- 15700 Dec 18 2009 15:56:20 +01:00 cfg-650x-VSS--Dec-18-14-56-21.019-12
68 -rw- 15421 Dec 18 2009 13:29:32 +01:00 cfg-650x-VSS--Dec-18-12-29-32.179-3
69 -rw- 15700 Dec 18 2009 15:57:26 +01:00 cfg-650x-VSS--Dec-18-14-57-26.143-13
70 -rw- 15372 Dec 18 2009 13:53:24 +01:00 cfg-650x-VSS--Dec-18-12-53-24.943-4
71 -rw- 15700 Dec 18 2009 16:44:52 +01:00 cfg-650x-VSS--Dec-18-15-44-53.218-14
72 -rw- 15421 Dec 18 2009 13:54:26 +01:00 cfg-650x-VSS--Dec-18-12-54-26.619-5
73 -rw- 15700 Dec 18 2009 16:49:44 +01:00 cfg-650x-VSS--Dec-18-15-49-45.006-15
74 -rw- 15421 Dec 18 2009 14:29:20 +01:00 cfg-650x-VSS--Dec-18-13-29-19.671-6
75 -rw- 17438 Dec 18 2009 17:11:58 +01:00 cfg-650x-VSS--Dec-18-16-11-59.038-16
76 -rw- 15463 Dec 18 2009 14:33:58 +01:00 cfg-650x-VSS--Dec-18-13-33-57.935-7
77 -rw- 17312 Dec 18 2009 17:20:16 +01:00 cfg-650x-VSS--Dec-18-16-20-15.630-17
78 -rw- 15567 Dec 18 2009 14:34:58 +01:00 cfg-650x-VSS--Dec-18-13-34-58.819-8
79 -rw- 17136 Dec 18 2009 17:39:44 +01:00 cfg-650x-VSS--Dec-18-16-39-44.914-18
80 -rw- 17136 Dec 18 2009 17:40:52 +01:00 cfg-650x-VSS--Dec-18-16-40-52.446-19
81 -rw- 17210 Dec 18 2009 19:55:38 +01:00 cfg-650x-VSS--Dec-18-18-55-37.922-20
82 -rw- 17210 Dec 18 2009 20:07:34 +01:00 cfg-650x-VSS--Dec-18-19-07-33.914-21
83 -rw- 17240 Dec 18 2009 20:08:58 +01:00 cfg-650x-VSS--Dec-18-19-08-58.398-22
84 -rw- 17262 Dec 18 2009 21:50:00 +01:00 cfg-650x-VSS--Dec-18-20-49-59.665-23
85 -rw- 15700 Dec 18 2009 16:49:44 +01:00 cfg-650x-VSS--Dec-18-15-49-43.482-15
86 -rw- 17438 Dec 18 2009 17:11:58 +01:00 cfg-650x-VSS--Dec-18-16-11-57.606-16
87 -rw- 17312 Dec 18 2009 17:20:14 +01:00 cfg-650x-VSS--Dec-18-16-20-13.858-17
88 -rw- 17136 Dec 18 2009 17:39:42 +01:00 cfg-650x-VSS--Dec-18-16-39-42.978-18
89 -rw- 17136 Dec 18 2009 17:40:50 +01:00 cfg-650x-VSS--Dec-18-16-40-50.858-19
90 -rw- 17210 Dec 18 2009 19:55:36 +01:00 cfg-650x-VSS--Dec-18-18-55-36.386-20
91 -rw- 17210 Dec 18 2009 20:07:32 +01:00 cfg-650x-VSS--Dec-18-19-07-32.474-21
92 -rw- 17240 Dec 18 2009 20:08:56 +01:00 cfg-650x-VSS--Dec-18-19-08-56.882-22
93 -rw- 17262 Dec 18 2009 21:49:58 +01:00 cfg-650x-VSS--Dec-18-20-49-58.117-23
94 -rw- 24997 Dec 21 2009 10:05:58 +01:00 cfg-650x-VSS-Dec-21-10-05-57.961-CEST-0
95 -rw- 24997 Dec 21 2009 10:05:58 +01:00 cfg-650x-VSS-Dec-21-10-05-59.333-CEST-0
96 -rw- 49383 Dec 21 2009 13:45:10 +01:00 cfg-650x-VSS-Dec-21-13-45-11.024-CEST-1
97 -rw- 49383 Dec 21 2009 13:45:12 +01:00 cfg-650x-VSS-Dec-21-13-45-11.948-CEST-1
98 -rw- 49383 Dec 21 2009 13:57:18 +01:00 cfg-650x-VSS-Dec-21-13-57-18.400-CEST-2
99 -rw- 49383 Dec 21 2009 13:57:20 +01:00 cfg-650x-VSS-Dec-21-13-57-19.960-CEST-2
100 -rw- 49356 Dec 21 2009 14:40:56 +01:00 cfg-650x-VSS-Dec-21-14-40-57.175-CEST-0
101 -rw- 49356 Dec 21 2009 14:40:58 +01:00 cfg-650x-VSS-Dec-21-14-40-58.531-CEST-0
102 -rw- 49649 Dec 22 2009 10:40:44 +01:00 cfg-650x-VSS-Dec-22-10-40-44.707-CEST-1
103 -rw- 49649 Dec 22 2009 10:40:46 +01:00 cfg-650x-VSS-Dec-22-10-40-46.047-CEST-1
104 -rw- 49005 Dec 23 2009 09:41:30 +01:00 cfg-650x-VSS-Dec-23-09-41-30.345-CEST-2
105 -rw- 49005 Dec 23 2009 09:41:32 +01:00 cfg-650x-VSS-Dec-23-09-41-31.581-CEST-2
106 -rw- 49025 Jan 5 2010 14:40:40 +01:00 cfg-650x-VSS-Jan--5-14-40-39.666-CEST-3
107 -rw- 49025 Jan 5 2010 14:40:40 +01:00 cfg-650x-VSS-Jan--5-14-40-41.022-CEST-3
108 -rw- 49025 Jan 7 2010 13:16:50 +01:00 cfg-650x-VSS-Jan--7-13-16-50.711-CEST-4
109 -rw- 49025 Jan 7 2010 13:16:52 +01:00 cfg-650x-VSS-Jan--7-13-16-51.903-CEST-4
110 -rw- 49048 Jan 19 2010 14:55:34 +01:00 cfg-650x-VSS-Jan-19-14-55-34.043-CEST-0
111 -rw- 49048 Jan 19 2010 14:55:34 +01:00 cfg-650x-VSS-Jan-19-14-55-35.239-CEST-0
112 -rw- 49173 Jan 19 2010 16:21:40 +01:00 cfg-650x-VSS-Jan-19-16-21-40.543-CEST-1
113 -rw- 49173 Jan 19 2010 16:21:42 +01:00 cfg-650x-VSS-Jan-19-16-21-41.831-CEST-1
114 -rw- 49236 Jan 19 2010 16:23:06 +01:00 cfg-650x-VSS-Jan-19-16-23-07.071-CEST-2
115 -rw- 49236 Jan 19 2010 16:23:08 +01:00 cfg-650x-VSS-Jan-19-16-23-08.367-CEST-2
116 -rw- 49394 Jan 22 2010 16:15:38 +01:00 cfg-650x-VSS-Jan-22-16-15-38.878-CEST-0
117 -rw- 49394 Jan 22 2010 16:15:40 +01:00 cfg-650x-VSS-Jan-22-16-15-40.254-CEST-0
118 -rw- 49524 Feb 5 2010 09:46:30 +01:00 cfg-650x-VSS-Feb--5-09-46-29.579-CEST-0
119 -rw- 49524 Feb 5 2010 09:46:30 +01:00 cfg-650x-VSS-Feb--5-09-46-30.879-CEST-0
120 -rw- 49591 Feb 5 2010 10:05:46 +01:00 cfg-650x-VSS-Feb--5-10-05-46.239-CEST-1
121 -rw- 49591 Feb 5 2010 10:05:48 +01:00 cfg-650x-VSS-Feb--5-10-05-47.599-CEST-1
122 -rw- 48886 Feb 12 2010 13:20:04 +01:00 cfg-650x-VSS-Feb-12-13-20-04.272-CEST-0
123 -rw- 48886 Feb 12 2010 13:20:04 +01:00 cfg-650x-VSS-Feb-12-13-20-05.440-CEST-0
124 -rw- 49449 Feb 12 2010 14:11:44 +01:00 cfg-650x-VSS-Feb-12-14-11-43.796-CEST-1
125 -rw- 49449 Feb 12 2010 14:11:44 +01:00 cfg-650x-VSS-Feb-12-14-11-45.108-CEST-1
126 -rw- 49514 Feb 12 2010 14:16:06 +01:00 cfg-650x-VSS-Feb-12-14-16-05.868-CEST-2
127 -rw- 49514 Feb 12 2010 14:16:06 +01:00 cfg-650x-VSS-Feb-12-14-16-07.372-CEST-2
128 -rw- 60249 Feb 12 2010 14:46:40 +01:00 cfg-650x-VSS-Feb-12-14-46-40.236-CEST-3
1024557056 bytes total (733904896 bytes free)
Directory of slavebootflash:/
1 -rw- 5608 Dec 8 2009 16:11:20 +01:00 startup-config.converted_vs-20091208-151104
65536000 bytes total (65530264 bytes free)
Directory of slavesystem:/
1 -rw- 54863 May 27 2010 22:08:23 +02:00 running-config
Directory of sw1-slot3-dfc-bootflash:/
Directory of sw1-slot1-dfc-bootflash:/
Your input about this error is welcome!
Thank you
Colin
03-17-2013 04:50 PM
It seems like you are hitting bug CSCtx51515. keep in mind bug is showed as fixed in the Other Resolved Caveats in Release 12.2(33)SXJ4 section:
03-17-2013 05:24 PM
If I remember correctly, I saw this error about 4 years ago when I was running early releases of the SXI train.
I think, the way I fixed the issue was by deleting all the archive commands in the primary VSS and also the stand-by.
It appears that IOS will not let you same your config if you have so many files on the flash. You can move the archive and save them some place else.
Also, SXI2a is at least 4 years old, and there are few bugs I remember about it. So, after fixing the issue, it is time for an upgrade.
