Highlighted
Enthusiast
Wrong Root port selected in PT-6.0
I just configured the below topology all the bridge id and port priorities are default.
Here Fa0/1 of switch2 should be ROOT port but Fa0/2 is becoming Root.
Can someone please explain me why ? Or i'm wrong somewhere.
O/P:
Switch1#show spanning-tree
VLAN0001
  Spanning tree enabled protocol ieee
  Root ID    Priority    32769
             Address     0001.C977.4431
             Cost        19
             Port        2(FastEthernet0/2)
             Hello Time  2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32769  (priority 32768 sys-id-ext 1)
             Address     00E0.F964.3896
             Aging Time  20
Interface        Role Sts Cost      Prio.Nbr Type
Fa0/1            Altn BLK 19        128.1    P2p
Fa0/2            Root FWD 19        128.2    P2p
Fa0/10           Desg FWD 19        128.10   P2p
Fa0/11           Desg FWD 19        128.11   P2p
Switch2#show spanning-tree
VLAN0001
             This bridge is the root
             Aging Time  20
Fa0/23           Desg FWD 19        128.23   P2p
Fa0/24           Desg FWD 19        128.24   P2p
Fa0/1            Desg FWD 19        128.1    P2p
Fa0/2            Desg FWD 19        128.2    P2p
Thanks in advance.
Chandu
Regards, Chandu
2 ACCEPTED SOLUTIONS
Highlighted
Rising star
Are the two switches connected by two ports? I can't see the picture. Everything is default?
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
Highlighted
Rising star
Actually PT is behaving correctly here. SW2 is chosen as root because it has lower MAC.
SW1 has two ports connected to SW2. The algorithm is like this:
1. Lowest cost to Root
2. Lowest sender BID (tie here)
3. Lowest sender port ID
Step nr.3 is why Fa0/2 becomes root port because that is connected to Fa0/23 which is lower than Fa0/24. If you want to change the behavior, either connect Fa0/1 to Fa0/23 or on SW2 go to Fa0/24 and configure spanning-tree port-priority 64.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
8 REPLIES 8
Highlighted
Rising star
Daniel Dib
CCIE #37149
CCDE #20160011
Highlighted
Enthusiast
Yes. Both switches are connected with two ports.
Sw1 Fa0/1 ---> SW2 Fa0/24
Sw1 Fa0/2 ---> SW2 Fa0/23
I thought it was the software issue and tried using PT in another systems with similar topology but sill the same bug.
I'm attaching my topology. Please take a look. And all the values are default.
O/p from Root swtich:
VLAN0001
             Address     00D0.BA39.0927
             Aging Time  20
Fa0/24           Desg FWD 19        128.24   P2p                    //Priorites are default to 128//
O/p from non-root switch:
VLAN0001
             Cost        19
             Address     00E0.F7EB.E8A8
             Aging Time  20
Fa0/1            Altn BLK 19        128.1    P2p               // This should be Root port //
Chandu
Regards, Chandu
Highlighted
Rising star
Packet tracer has some odd quirks with spanning tree
Highlighted
Enthusiast
Hi Devil,
Can you please give me a clarification on this:
Root Port Selection:
1. If cost are same then
2. Check priorties on negihbour switch if BPDUs are from one swtich
3. If priorites are same
Question:
4. then compare the Port Numbers of Sending switch or own switch.
Chandu
Regards, Chandu
Highlighted
Enthusiast
Hi All,
Bug here is not with PT but with my understanding of Root port selection in STP.
I thought STP will compare Port numbers on switch1 in my topology. So, as per that i was thinking Fa0/1 should be Root port but STP never does that whereas it compares the Port numbers on Switch2.
So since Fa0/23 is lesser than Fa0/24. The port on Switch1 i.e, Fa0/2 connected to the Fa0/23 of Swtich2 will become Root port. That's what happended..
Output from switch1:
This is absolutley correct.
Regard,
Chandu
Regards, Chandu
Highlighted
Enthusiast
Can somone please mark my answer as correct answer ? Because i cannot mark it. And this question will be unanswered forever.
Chandu
Regards, Chandu
Highlighted
Rising star
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Highlighted
Enthusiast
Yes Daniel thats correct. I understood it after a deep going through STP root port selection with different ports and priorities.
Chandu
Regards, Chandu
Content for Community-Ad
