wrr-queue questions
retheridge
having issues removing the wrr-queue bandwidth statements on catalast 6500 interface
Chad Peterson
What module are you using that shows them?  Also what commands do you see?
I'm guessing that at one time they were altered so now they show up in the config.
At one point the interface was used as a voip
interface GigabitEthernet8/10
switchport
switchport mode trunk
no ip address
logging event link-status
shutdown
wrr-queue random-detect min-threshold 2 70 80
wrr-queue random-detect max-threshold 1 80 100
wrr-queue random-detect max-threshold 2 80 100
wrr-queue cos-map 1 1 1
wrr-queue cos-map 1 2 0
wrr-queue cos-map 2 1 2 3 4
wrr-queue cos-map 2 2 6 7
mls qos trust dscp
Please find the explanation below:
wrr-queue cos-map 1 1 1          Maps queue 1 threshold 1 to cos 1
wrr-queue cos-map 1 2 0         Maps queue 1 threshold 2 to cos 0
wrr-queue cos-map 2 1 2 3 4    Maps queue 2 threshold 1 to cos 2,3,4
wrr-queue cos-map 2 2 6 7       Maps queue 2 threshold 2 to cos 6,7
This enables minimum and maximum values for WRED for the queues. wrr-queue random-detect min-threshold 2 70 80 means that minimum values for queue2 threshold 1 is 70% and queue2 threshold 2 is 80% and likewise. Detailed information is available at
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/command/reference/W1.html#wp1038830
Cheers,
Shashank
Please rate if this helped answer your question
