WS-c2924-XL-A
todstercisco
What version of IOS can this use? Or do I have to use the original? The original won't boot and I tried the upgrade to c2900xl-c3h2s-mz.120-5.WC17.bin
This is the enterprise version and my understanding is that it will not work on the -A. How can I obtain the original IOS that this works with. I obtained this2nd hand and it did not boot some am guessing that someone messed with the Bin.
TIA
6 Replies 6
Reza Sharifi
Todd,
You have to have a service contract with Cisco and CCO account to download IOS images.  If this is a second hand device and no contract, then you can not download any other version for it. You just have to try to recover the existing image, if possible
This link is for password recovery, but see if you can boot to Rommon and find the image on the flash
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
Reza
glen.grant
  Is this a 4 meg or 8 meg model ?  A show version will tell you that ..  You can go here to download a version you need .
ftp://ftp.cisco.com/pub/lan/catalyst/2900XL/
It's the 4/8 mb ?
The site says it uses the 12.05 yet everything I've seen says this is not the enterprise version and it won't run the newer versions.
I can't seem to get it to see my tftp server for anything. I'm trying the
xmodem with >copy xmodem flash:c2900xl-c3h2s-mz.120-5.WC16.bin
  and it then says >source filename [xmodem]  then destination fileNAME [c2900xl-c3h2s-mz.120-5.WC16.bin]  then comes up with error and never prompts me to start xmodem on hyperterminal. I did manage to switch to 115,000 so maybe thats the problem. I just can't get it back to 9600 now.
cisco WS-C2924-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K byte
s of memory.
Processor board ID 0x0E, with hardware revision 0x01
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:D0:58:A4:EC:C0
Motherboard assembly number: 73-3382-04
Power supply part number: 34-0834-01
Motherboard serial number: FAA03169NYY
Power supply serial number: DAB031202GR
Model revision number: A0
Model number: WS-C2924-XL-A
System serial number: FAA0320H0EF
Configuration register is 0xF
I'm going to slap myself for you.  Forgot the : after x
modem.  Giving the c2900xl-c3h2s-mz.120-5.WC16.bin a whirl.
cranks right along at 115k.
