WS-C2960+24TC-L Bootup issue
Arsalan Noor
Dear folks,
i have cisco 2960TC-L 24port switch, but after start just mode light is blinking continuously while console view has shown abnormally language. i.e -30)/@<><?|}{|}|}"|")|_|?}|()*^&*^&*|"|":}|P"|/@<><P:P}":P"}P"P"P:|?/@<><>?<><<<. even any key type but abnormally language is showing. if anyone have faced this issue pls let me know.
Reza Sharifi
On your console settings, try a different baud rate from 9600 and go up.
https://www.cisco.com/c/en/us/support/docs/dial-access/asynchronous-connections/9321-terminal-settings.html
Tried but still same.
marce1000
   - Try tapping the space bar during boot, check if that helps.
 M.
balaji.bandi
can you post the baud rate setting and let us know what terminal emulator you using?
BB
