06-28-2011 02:31 AM - last edited on 03-25-2019 04:15 PM by ciscomoderator
Hi All,
have WS-C2960G-48TC-L switch, i am facing latency issue while pinging from the server to the switch. Also I am able to see high broadcas packets in all the connected interface. How to resolve this latency issue..
Received 3873877 broadcasts (3817040 multicasts)
Reply from 192.168.3.254: bytes=32 time=11ms TTL=126
Reply from 192.168.3.254: bytes=32 time=5ms TTL=126
06-28-2011 02:52 AM
for the supposed latency issue pinging TO/FROM a switch is never a good idea as the latency can be just added by this.
Switches are platforms which handle traffic in hardware while traffic destined to/from them is handled by the CPU which is not as performing as the port ASICs.
So first thing you need to do to check this out is pinging from the server to another host in the same vlan connected to the same 2960.
In this case the traffic will go THROUGH the switch and you will be able to make more accurate consideration about latency.
Riccardo
06-28-2011 05:29 AM
I am facing the same issue while pinging to the other server which is in same LAN. Is that coz of any broadcast / multicast packet ? As i can see more broadcast packet in all connected interface.
06-28-2011 05:01 AM
could you show us output of
show processes cpu | exclude 0.00%__0.00%__0.00%
06-28-2011 05:24 AM
HI Rob,
I have mentioned CPU and the interface output from the switch.
------------------ show process cpu ------------------
CPU utilization for five seconds: 7%/0%; one minute: 6%; five minutes: 6%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 6 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 381 5483000 0 0.00% 0.00% 0.00% 0 Load Meter
3 608 1589 382 0.00% 0.00% 0.00% 0 SpanTree Helper
4 9345034 2788357 3351 0.00% 0.01% 0.00% 0 Check heaps
5 59 4737 12 0.00% 0.00% 0.00% 0 Pool Manager
6 0 2 0 0.00% 0.00% 0.00% 0 Timers
7 16 294 54 0.00% 0.00% 0.00% 0 Net Input
8 0 1 0 0.00% 0.00% 0.00% 0 Crash writer
9 2330811 9922880 234 0.00% 0.00% 0.00% 0 ARP Input
10 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
11 0 2 0 0.00% 0.00% 0.00% 0 AAA high-capacit
12 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
13 58 38 1526 0.00% 0.00% 0.00% 0 Entity MIB API
14 0 1 0 0.00% 0.00% 0.00% 0 IFS Agent Manage
15 0 2 0 0.00% 0.00% 0.00% 0 XML Proxy Client
16 628662 27128677 23 0.00% 0.00% 0.00% 0 Dynamic ARP Insp
17 0 1 0 0.00% 0.00% 0.00% 0 ARP Snoop
18 5649182 27128662 208 0.00% 0.00% 0.00% 0 GraphIt
19 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
20 1013375 61117049 16 0.00% 0.00% 0.00% 0 Net Background
21 0 1 0 0.00% 0.00% 0.00% 0 IDB Work
22 345 2213 155 0.00% 0.00% 0.00% 0 Logger
23 3560622 27128658 131 0.00% 0.00% 0.00% 0 TTY Background
24 17994426 27128677 663 0.15% 0.02% 0.00% 0 Per-Second Jobs
25 4426887 462279 9576 0.00% 0.01% 0.00% 0 Per-minute Jobs
26 8 4 2000 0.00% 0.00% 0.00% 0 IF-MGR control p
27 18 1107 16 0.00% 0.00% 0.00% 0 IF-MGR event pro
28 0 1 0 0.00% 0.00% 0.00% 0 AggMgr Process
29 13662415 5475644 2495 0.00% 0.04% 0.05% 0 Compute load avg
30 907249 8205986 110 0.00% 0.00% 0.00% 0 HC Counter Timer
31 23146 545211240 0 0.00% 0.00% 0.00% 0 DownWhenLooped
32 0 1 0 0.00% 0.00% 0.00% 0 HRPC lpip reques
33 0 2 0 0.00% 0.00% 0.00% 0 HLPIP Sync Proce
34 0 4 0 0.00% 0.00% 0.00% 0 HL2MCM
35 0 4 0 0.00% 0.00% 0.00% 0 HL2MCM
36 0 1 0 0.00% 0.00% 0.00% 0 HRPC asic-stats
37 0 1 0 0.00% 0.00% 0.00% 0 HRPC hsm request
38 0 7 0 0.00% 0.00% 0.00% 0 Stack Mgr
39 236 5 47200 0.00% 0.00% 0.00% 0 Stack Mgr Notifi
40 825423921457218430 56 0.31% 0.33% 0.32% 0 Fifo Error Detec
41 9 3 3000 0.00% 0.00% 0.00% 0 Adjust Regions
42 16485806 27128691 607 0.00% 0.02% 0.01% 0 hrpc -> response
43 16738 5475648 3 0.00% 0.00% 0.00% 0 hrpc -> request
44 2115076 5475661 386 0.00% 0.00% 0.00% 0 hrpc <- response
45 0 1 0 0.00% 0.00% 0.00% 0 HRPC hcomp reque
46 0 3 0 0.00% 0.00% 0.00% 0 HULC Device Mana
47 0 3 0 0.00% 0.00% 0.00% 0 HRPC hdm non blo
48 0 2 0 0.00% 0.00% 0.00% 0 HRPC hdm blockin
49 16 2154 7 0.00% 0.00% 0.00% 0 Hulc Port-Securi
50 0 1 0 0.00% 0.00% 0.00% 0 HRPC hpsecure re
51 0 1 0 0.00% 0.00% 0.00% 0 HRPC hlfm reques
52 13424441 813455307 16 0.00% 0.04% 0.04% 0 HLFM address lea
53 4349811 27128663 160 0.15% 0.02% 0.00% 0 HLFM aging proce
54 3731329 813510913 4 0.00% 0.00% 0.00% 0 HLFM address ret
55 0 1 0 0.00% 0.00% 0.00% 0 HRPC hulc misc r
56 0 1 0 0.00% 0.00% 0.00% 0 HRPC system mtu
57 46303 9142826 5 0.00% 0.00% 0.00% 0 HVLAN main bkgrd
58 0 2 0 0.00% 0.00% 0.00% 0 HVLAN Mapped Vla
59 0 2 0 0.00% 0.00% 0.00% 0 Vlan shutdown Pr
60 0 1 0 0.00% 0.00% 0.00% 0 HRPC vlan reques
61 0 1 0 0.00% 0.00% 0.00% 0 HULC VLAN REF Ba
62 0 1 0 0.00% 0.00% 0.00% 0 HRPC ilp request
63 0 1 0 0.00% 0.00% 0.00% 0 HULC PM Vector P
64 0 1 0 0.00% 0.00% 0.00% 0 HPM Msg Retry Pr
65 77918 15540324 5 0.00% 0.00% 0.00% 0 NTP
66 16556293 227031346 72 0.15% 0.07% 0.05% 0 hpm main process
67 68 2054 33 0.00% 0.00% 0.00% 0 HPM Stack Sync P
68 0 1 0 0.00% 0.00% 0.00% 0 HRPC pm request
69 149559634 27128662 5512 0.47% 0.52% 0.53% 0 hpm counter proc
70 0 1 0 0.00% 0.00% 0.00% 0 HRPC pm-counters
71 0 1 0 0.00% 0.00% 0.00% 0 hpm vp events ca
72 0 1 0 0.00% 0.00% 0.00% 0 HRPC hcmp reques
73 0 1 0 0.00% 0.00% 0.00% 0 HACL Queue Proce
74 0 1 0 0.00% 0.00% 0.00% 0 HRPC acl request
75 0 6 0 0.00% 0.00% 0.00% 0 HACL Acl Manager
76 0 1 0 0.00% 0.00% 0.00% 0 HRPC backup inte
78 0 1 0 0.00% 0.00% 0.00% 0 HRPC cdp request
79 0 1 0 0.00% 0.00% 0.00% 0 HRPC lldp reques
80 0 1 0 0.00% 0.00% 0.00% 0 HRPC dot1x reque
81 0 3 0 0.00% 0.00% 0.00% 0 HULC DOT1X Proce
82 0 1 0 0.00% 0.00% 0.00% 0 HRPC sdm request
83 11258314 135642425 82 0.00% 0.04% 0.01% 0 Hulc Storm Contr
84 0 2 0 0.00% 0.00% 0.00% 0 HSTP Sync Proces
85 0 1 0 0.00% 0.00% 0.00% 0 HRPC stp_cli req
86 0 1 0 0.00% 0.00% 0.00% 0 HRPC stp_state_s
87 0 2 0 0.00% 0.00% 0.00% 0 S/W Bridge Proce
88 0 1 0 0.00% 0.00% 0.00% 0 HRPC hudld reque
89 0 1 0 0.00% 0.00% 0.00% 0 HRPC vqpc reques
90 0 1 0 0.00% 0.00% 0.00% 0 BCM cable diags
91 0 1 0 0.00% 0.00% 0.00% 0 HRPC hled reques
92 16528083 654018771 25 0.00% 0.04% 0.05% 0 Hulc LED Process
93 0 1 0 0.00% 0.00% 0.00% 0 HRPC dtp request
94 0 1 0 0.00% 0.00% 0.00% 0 HRPC show_forwar
95 0 1 0 0.00% 0.00% 0.00% 0 HRPC snmp reques
96 66298475 5475648 12107 0.31% 0.22% 0.21% 0 HQM Stack Proces
97 349646 10951277 31 0.00% 0.00% 0.00% 0 HRPC qos request
98 0 1 0 0.00% 0.00% 0.00% 0 HRPC span reques
99 0 1 0 0.00% 0.00% 0.00% 0 HRPC system post
100 0 1 0 0.00% 0.00% 0.00% 0 Hulc Reload Mana
101 0 1 0 0.00% 0.00% 0.00% 0 HRPC hrcli-event
102 0 2 0 0.00% 0.00% 0.00% 0 image mgr
103 26688253 27128662 983 0.15% 0.18% 0.16% 0 PI MATM Aging Pr
104 0 2 0 0.00% 0.00% 0.00% 0 Switch Backup In
105 678 457615 1 0.00% 0.00% 0.00% 0 MMN bkgrd proces
106 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Mgr Proces
107 0 2 0 0.00% 0.00% 0.00% 0 802.1x Accountin
108 0 1 0 0.00% 0.00% 0.00% 0 MAB Framework
109 0 516 0 0.00% 0.00% 0.00% 0 802.1x switch
110 0 1 0 0.00% 0.00% 0.00% 0 802.1x Webauth F
111 608990 17256246 35 0.00% 0.00% 0.00% 0 DTP Protocol
112 0 1 0 0.00% 0.00% 0.00% 0 EAP Framework
113 0 1 0 0.00% 0.00% 0.00% 0 HRPC dai request
114 0 1 0 0.00% 0.00% 0.00% 0 HULC DAI Process
115 0 1 0 0.00% 0.00% 0.00% 0 HRPC ip device t
116 5360 27458685 0 0.00% 0.00% 0.00% 0 UDLD
117 1838 915290 2 0.00% 0.00% 0.00% 0 Port-Security
118 42 1074 39 0.00% 0.00% 0.00% 0 Switch IP Host T
119 0 1 0 0.00% 0.00% 0.00% 0 Link State Group
120 366 1291 283 0.00% 0.00% 0.00% 0 VMATM Callback
121 0 2 0 0.00% 0.00% 0.00% 0 AAA Server
122 0 1 0 0.00% 0.00% 0.00% 0 AAA ACCT Proc
123 0 1 0 0.00% 0.00% 0.00% 0 ACCT Periodic Pr
124 0 1 0 0.00% 0.00% 0.00% 0 AAA System Acct
125 0 1 0 0.00% 0.00% 0.00% 0 Auth-proxy AAA B
126 369 91529 4 0.00% 0.00% 0.00% 0 IP Admin SM Proc
127 2003330 9603294 208 0.00% 0.00% 0.00% 0 CDP Protocol
128 2211 259 8536 0.00% 0.00% 0.00% 1 Virtual Exec
129 0 1 0 0.00% 0.00% 0.00% 0 HRPC hl2mcm igmp
130 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R
131 2017 228823 8 0.00% 0.00% 0.00% 0 DHCP Snooping
132 2015916 16106308 125 0.00% 0.00% 0.00% 0 IP Input
133 0 1 0 0.00% 0.00% 0.00% 0 ICMP event handl
134 74996 52995656 1 0.00% 0.00% 0.00% 0 IP ARP Track
136 10259372 27789837 369 0.00% 0.01% 0.00% 0 Spanning Tree
137 534 457621 1 0.00% 0.00% 0.00% 0 Spanning Tree St
138 2900 2744396 1 0.00% 0.00% 0.00% 0 Ethchnl
139 806 343226 2 0.00% 0.00% 0.00% 0 Cluster L2
140 5762 2744395 2 0.00% 0.00% 0.00% 0 Cluster RARP
141 136834 3888649 35 0.00% 0.00% 0.00% 0 Cluster Base
142 0 32 0 0.00% 0.00% 0.00% 0 DHCPD Receive
143 319 7710 41 0.00% 0.00% 0.00% 0 TCP Timer
144 0 39 0 0.00% 0.00% 0.00% 0 TCP Protocols
145 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers
146 107943 180117 599 0.00% 0.00% 0.00% 0 HTTP CORE
147 17 294 57 0.00% 0.00% 0.00% 0 RARP Input
148 0 1 0 0.00% 0.00% 0.00% 0 802.1x Critical
149 0 1 0 0.00% 0.00% 0.00% 0 HRPC dhcp snoopi
150 0 4 0 0.00% 0.00% 0.00% 0 HULC DHCP Snoopi
151 169 1374 122 0.00% 0.00% 0.00% 0 IGMPSN L2MCM
152 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN MRD
153 687 1186 579 0.00% 0.00% 0.00% 0 IGMPSN
154 0 1 0 0.00% 0.00% 0.00% 0 IGMPQR
155 0 2 0 0.00% 0.00% 0.00% 0 L2TRACE SERVER
156 43 1367 31 0.00% 0.00% 0.00% 0 MLDSN L2MCM
157 0 1 0 0.00% 0.00% 0.00% 0 MRD
158 0 1 0 0.00% 0.00% 0.00% 0 MLD_SNOOP
159 0 148 0 0.00% 0.00% 0.00% 0 Transport Port A
160 0 2 0 0.00% 0.00% 0.00% 0 TPLUS
161 424 152549 2 0.00% 0.00% 0.00% 0 HCMP sync proces
162 0 2 0 0.00% 0.00% 0.00% 0 LOCAL AAA
163 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA
164 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA
166 0 1 0 0.00% 0.00% 0.00% 0 HRPC hl2mcm mlds
167 0 1 0 0.00% 0.00% 0.00% 0 HRPC x_setup req
168 9 12 750 0.00% 0.00% 0.00% 0 crypto engine pr
169 0 1 0 0.00% 0.00% 0.00% 0 encrypt proc
170 0 4 0 0.00% 0.00% 0.00% 0 Crypto CA
171 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-CRL
172 0 1 0 0.00% 0.00% 0.00% 0 Crypto SSL
173 0 13 0 0.00% 0.00% 0.00% 0 VTP Trap Process
174 0 2 0 0.00% 0.00% 0.00% 0 VTPMIB EDIT BUFF
175 0 1 0 0.00% 0.00% 0.00% 0 HCD Process
176 0 1 0 0.00% 0.00% 0.00% 0 HRPC cable diagn
177 665751 150215289 4 0.00% 0.00% 0.00% 0 PM Callback
178 8 6 1333 0.00% 0.00% 0.00% 0 VLAN Manager
179 2486 2195481 1 0.00% 0.00% 0.00% 0 dhcp snooping sw
180 0 2 0 0.00% 0.00% 0.00% 0 AAA SEND STOP EV
181 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps
182 317 228810 1 0.00% 0.00% 0.00% 0 DHCPD Timer
183 403 1242 324 0.00% 0.00% 0.00% 0 Syslog
184 0 2 0 0.00% 0.00% 0.00% 0 STP FAST TRANSIT
185 0 2 0 0.00% 0.00% 0.00% 0 CSRT RAPID TRANS
187 3854 15251 252 0.00% 0.00% 0.00% 0 SSH Event handle
188 20414 7777434 2 0.00% 0.00% 0.00% 0 DHCPD Database
189 11208241 57112 196250 0.00% 0.00% 0.07% 0 crypto sw pk pro
------------------ show process cpu history ------------------
7777666666666666666777776666666666666666666666666666666666
100
90
80
70
60
50
40
30
20
10 **********************************************************
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per second (last 60 seconds)
22
7767776677777777777666667677777777777777776677777788777777
100
90
80
70
60
50
40
30 **
20 **
10 ##########################################################
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
2332423211124532135333353334221132225137232424322352232222243283224332
2119208564762009404948611077526715977599043206020557306539272821592078
100
90
80 * *
70 * *
60 * * * *
50 * * * * * * * * * *
40 * * ** ** *** ** * ** * * ** * * * *
30 **** ** ***** ************ ***** ** * * ** *** *** * ***********
20 ********* ****** *****************************************************
10 ######################################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
------------------ show interfaces ------------------
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is 2893.fe33.d240 (bia 2893.fe33.d240)
Internet address is 192.168.3.9/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not supported
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 5/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
25659541 packets input, 1933728250 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
1522138 packets output, 168080177 bytes, 0 underruns
0 output errors, 0 interface resets
GigabitEthernet0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d201 (bia 2893.fe33.d201)
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 45w2d, output 00:00:01, output hang never
5 minute input rate 23000 bits/sec, 6 packets/sec
5 minute output rate 4000 bits/sec, 5 packets/sec
14775742708 packets input, 19498232211648 bytes, 0 no buffer
Received 122859 broadcasts (50 multicasts)
0 watchdog, 50 multicast, 0 pause input
6152505200 packets output, 549237224832 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
GigabitEthernet0/2 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d202 (bia 2893.fe33.d202)
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
GigabitEthernet0/3 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d203 (bia 2893.fe33.d203)
GigabitEthernet0/4 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d204 (bia 2893.fe33.d204)
Last input never, output 42w1d, output hang never
4439221808 packets input, 6674942261809 bytes, 0 no buffer
Received 19973 broadcasts (0 multicasts)
1542256438 packets output, 141995838710 bytes, 0 underruns
GigabitEthernet0/5 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d205 (bia 2893.fe33.d205)
GigabitEthernet0/6 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d206 (bia 2893.fe33.d206)
GigabitEthernet0/7 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d207 (bia 2893.fe33.d207)
GigabitEthernet0/8 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d208 (bia 2893.fe33.d208)
Last input 43w4d, output 43w4d, output hang never
568 packets input, 38335 bytes, 0 no buffer
Received 14 broadcasts (13 multicasts)
0 watchdog, 13 multicast, 0 pause input
23122338 packets output, 21957037585 bytes, 0 underruns
GigabitEthernet0/9 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d209 (bia 2893.fe33.d209)
GigabitEthernet0/10 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d20a (bia 2893.fe33.d20a)
GigabitEthernet0/11 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d20b (bia 2893.fe33.d20b)
GigabitEthernet0/12 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d20c (bia 2893.fe33.d20c)
GigabitEthernet0/13 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d20d (bia 2893.fe33.d20d)
GigabitEthernet0/14 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d20e (bia 2893.fe33.d20e)
GigabitEthernet0/15 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d20f (bia 2893.fe33.d20f)
Last input 00:00:00, output 00:00:01, output hang never
5 minute input rate 1000 bits/sec, 1 packets/sec
5 minute output rate 1000 bits/sec, 1 packets/sec
5412383 packets input, 1222770869 bytes, 0 no buffer
0 watchdog, 3817040 multicast, 0 pause input
9192940 packets output, 1282658578 bytes, 0 underruns
GigabitEthernet0/16 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d210 (bia 2893.fe33.d210)
5915657 packets input, 1323136274 bytes, 0 no buffer
Received 3799590 broadcasts (3748431 multicasts)
0 watchdog, 3748431 multicast, 0 pause input
5697831 packets output, 444902841 bytes, 0 underruns
GigabitEthernet0/17 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d211 (bia 2893.fe33.d211)
Last input never, output 00:00:01, output hang never
5 minute input rate 237000 bits/sec, 15 packets/sec
5 minute output rate 28000 bits/sec, 11 packets/sec
5864125428 packets input, 8047220712046 bytes, 0 no buffer
Received 478594 broadcasts (0 multicasts)
0 runts, 5881 giants, 0 throttles
3071441533 packets output, 469505920898 bytes, 0 underruns
GigabitEthernet0/18 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d212 (bia 2893.fe33.d212)
Last input never, output 5w5d, output hang never
42227 packets input, 5550048 bytes, 0 no buffer
Received 349 broadcasts (10 multicasts)
0 watchdog, 10 multicast, 0 pause input
63603 packets output, 24652839 bytes, 0 underruns
GigabitEthernet0/19 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d213 (bia 2893.fe33.d213)
GigabitEthernet0/20 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d214 (bia 2893.fe33.d214)
Last input never, output 45w2d, output hang never
17320 packets input, 1602116 bytes, 0 no buffer
Received 808 broadcasts (29 multicasts)
0 watchdog, 29 multicast, 0 pause input
83130 packets output, 20458778 bytes, 0 underruns
GigabitEthernet0/21 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d215 (bia 2893.fe33.d215)
Last input never, output 00:00:00, output hang never
5 minute input rate 729000 bits/sec, 106 packets/sec
5 minute output rate 64000 bits/sec, 54 packets/sec
4269835607 packets input, 3926130210473 bytes, 0 no buffer
Received 355154 broadcasts (0 multicasts)
3269143393 packets output, 1965413154461 bytes, 0 underruns
GigabitEthernet0/22 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d216 (bia 2893.fe33.d216)
GigabitEthernet0/23 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d217 (bia 2893.fe33.d217)
5 minute input rate 413000 bits/sec, 93 packets/sec
5 minute output rate 298000 bits/sec, 94 packets/sec
7346453668 packets input, 8811675640882 bytes, 0 no buffer
Received 394097 broadcasts (0 multicasts)
4389338631 packets output, 949939286275 bytes, 0 underruns
GigabitEthernet0/24 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d218 (bia 2893.fe33.d218)
Last input 5w5d, output 5w5d, output hang never
137 packets input, 15970 bytes, 0 no buffer
Received 137 broadcasts (50 multicasts)
79 packets output, 6505 bytes, 0 underruns
GigabitEthernet0/25 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d219 (bia 2893.fe33.d219)
GigabitEthernet0/26 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d21a (bia 2893.fe33.d21a)
GigabitEthernet0/27 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d21b (bia 2893.fe33.d21b)
5 minute input rate 229000 bits/sec, 80 packets/sec
5 minute output rate 139000 bits/sec, 242 packets/sec
1366118017 packets input, 347270194139 bytes, 0 no buffer
Received 258538 broadcasts (214004 multicasts)
0 watchdog, 214004 multicast, 0 pause input
3490985273 packets output, 381990469947 bytes, 0 underruns
GigabitEthernet0/28 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d21c (bia 2893.fe33.d21c)
5 minute input rate 227000 bits/sec, 467 packets/sec
5 minute output rate 164000 bits/sec, 273 packets/sec
5693979110 packets input, 608464469167 bytes, 0 no buffer
Received 315548 broadcasts (214571 multicasts)
0 watchdog, 214571 multicast, 0 pause input
3473592330 packets output, 344767968882 bytes, 0 underruns
GigabitEthernet0/29 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d21d (bia 2893.fe33.d21d)
5 minute input rate 2228000 bits/sec, 339 packets/sec
5 minute output rate 2013000 bits/sec, 365 packets/sec
6923772435 packets input, 5130186019789 bytes, 0 no buffer
Received 844357 broadcasts (45048 multicasts)
0 watchdog, 45048 multicast, 0 pause input
8551861163 packets output, 6655690560360 bytes, 0 underruns
GigabitEthernet0/30 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d21e (bia 2893.fe33.d21e)
GigabitEthernet0/31 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d21f (bia 2893.fe33.d21f)
5 minute input rate 2000 bits/sec, 2 packets/sec
5 minute output rate 3000 bits/sec, 4 packets/sec
75277152001 packets input, 6290574477914 bytes, 0 no buffer
Received 928852 broadcasts (0 multicasts)
168332184544 packets output, 247766742552698 bytes, 0 underruns
GigabitEthernet0/32 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d220 (bia 2893.fe33.d220)
5 minute output rate 1000 bits/sec, 2 packets/sec
20309954 packets input, 2641308854 bytes, 0 no buffer
Received 103897 broadcasts (0 multicasts)
160062298 packets output, 100333486451 bytes, 0 underruns
GigabitEthernet0/33 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d221 (bia 2893.fe33.d221)
19305571 packets input, 1235556544 bytes, 0 no buffer
Received 91915 broadcasts (0 multicasts)
159224141 packets output, 100242279956 bytes, 0 underruns
GigabitEthernet0/34 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d222 (bia 2893.fe33.d222)
5 minute input rate 265000 bits/sec, 39 packets/sec
5 minute output rate 562000 bits/sec, 62 packets/sec
11067442083 packets input, 15834773615827 bytes, 0 no buffer
Received 544670 broadcasts (0 multicasts)
5803570967 packets output, 889048799049 bytes, 0 underruns
GigabitEthernet0/35 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d223 (bia 2893.fe33.d223)
5 minute input rate 627000 bits/sec, 69 packets/sec
5 minute output rate 185000 bits/sec, 42 packets/sec
25198054316 packets input, 36535411147176 bytes, 0 no buffer
Received 522781 broadcasts (17 multicasts)
0 watchdog, 17 multicast, 0 pause input
10199060570 packets output, 1048305196688 bytes, 0 underruns
GigabitEthernet0/36 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d224 (bia 2893.fe33.d224)
554048106 packets input, 713651704731 bytes, 0 no buffer
Received 226785 broadcasts (15 multicasts)
0 watchdog, 15 multicast, 0 pause input
367364559 packets output, 167808935663 bytes, 0 underruns
GigabitEthernet0/37 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d225 (bia 2893.fe33.d225)
19306702 packets input, 1235685326 bytes, 0 no buffer
Received 101775 broadcasts (0 multicasts)
159235517 packets output, 100227550554 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
GigabitEthernet0/38 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d226 (bia 2893.fe33.d226)
3711891925 packets input, 5445629548722 bytes, 0 no buffer
Received 383644 broadcasts (0 multicasts)
1123948777 packets output, 235005569398 bytes, 0 underruns
GigabitEthernet0/39 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d227 (bia 2893.fe33.d227)
17222281 packets input, 1102947590 bytes, 0 no buffer
Received 93502 broadcasts (0 multicasts)
157287073 packets output, 100132172283 bytes, 0 underruns
GigabitEthernet0/40 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d228 (bia 2893.fe33.d228)
5 minute input rate 1608000 bits/sec, 538 packets/sec
5 minute output rate 1230000 bits/sec, 516 packets/sec
30701308273 packets input, 36569940590429 bytes, 0 no buffer
Received 475505 broadcasts (12 multicasts)
0 watchdog, 12 multicast, 0 pause input
19190137177 packets output, 2986354053641 bytes, 0 underruns
GigabitEthernet0/41 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d229 (bia 2893.fe33.d229)
17305688 packets input, 1119062485 bytes, 0 no buffer
Received 95858 broadcasts (0 multicasts)
157392082 packets output, 100132399692 bytes, 0 underruns
GigabitEthernet0/42 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d22a (bia 2893.fe33.d22a)
5 minute input rate 1024000 bits/sec, 443 packets/sec
5 minute output rate 871000 bits/sec, 449 packets/sec
87480370888 packets input, 119902894089798 bytes, 0 no buffer
Received 367785 broadcasts (3 multicasts)
0 watchdog, 3 multicast, 0 pause input
43753214034 packets output, 4596028458710 bytes, 0 underruns
GigabitEthernet0/43 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d22b (bia 2893.fe33.d22b)
420892 packets input, 151834425 bytes, 0 no buffer
Received 1212 broadcasts (0 multicasts)
115961185 packets output, 76138785495 bytes, 0 underruns
GigabitEthernet0/44 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d22c (bia 2893.fe33.d22c)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3242
94366 packets input, 40345063 bytes, 0 no buffer
Received 1312 broadcasts (3 multicasts)
102184231 packets output, 64158303006 bytes, 0 underruns
GigabitEthernet0/45 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d22d (bia 2893.fe33.d22d)
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is Not Present
Last input 43w4d, output 3w5d, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 38
1318083 packets input, 100341180 bytes, 0 no buffer
Received 12222 broadcasts (6216 multicasts)
0 watchdog, 6216 multicast, 0 pause input
4472065 packets output, 4799475439 bytes, 0 underruns
GigabitEthernet0/46 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d22e (bia 2893.fe33.d22e)
Keepalive not set
Last input never, output 38w5d, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 292
9261497 packets input, 6822475399 bytes, 0 no buffer
Received 5978 broadcasts (2628 multicasts)
0 watchdog, 2628 multicast, 0 pause input
9698884 packets output, 7996694017 bytes, 0 underruns
GigabitEthernet0/47 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 2893.fe33.d22f (bia 2893.fe33.d22f)
Keepalive not set
Last input never, output 43w4d, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 47
1067949 packets input, 1502444100 bytes, 0 no buffer
Received 4035 broadcasts (1404 multicasts)
0 watchdog, 1404 multicast, 0 pause input
1458632 packets output, 969399939 bytes, 0 underruns
GigabitEthernet0/48 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2893.fe33.d230 (bia 2893.fe33.d230)
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX
Last input 00:00:01, output 00:00:09, output hang never
5 minute input rate 1375000 bits/sec, 825 packets/sec
5 minute output rate 3433000 bits/sec, 904 packets/sec
14862781950 packets input, 5404615713096 bytes, 0 no buffer
Received 31868160 broadcasts (26133571 multicasts)
0 watchdog, 26133571 multicast, 0 pause input
18468453221 packets output, 11713120116565 bytes, 0 underruns
06-28-2011 05:36 AM
Hi Anuradha,
The received broadcast packets should be less than 20 percent of the total received packets.
If it is high, this could be an indication of a high network load or a problem with Spanning Tree.
Check for any such possible issues.
Sweta
P.S. Please rate helpful answers.
06-30-2011 05:52 AM
I don't see anything strange ont he switch in general
So it might be that the little/micro latency (we are still talking of 5ms as average which is pretty low) is added by the server itself which might be busy with other more importnat tasks.
Also I don't think that bcast and mcast cause any issue here.
3 suggestions:
1) connect to 2 free ports in the same vlan 2 PCs and ping between them.
2) use iperf on the PCs and test sending UDP traffic instead of ICMP and check if there is any difference.
3) use iperf on the servers and compare the result.
Nice iperf tutorial is here:
http://openmaniak.com/iperf.php
Riccardo
