Join Customer Connection to register!
117
saleem771
Beginner
WS-C2960PS-L v02 booting issue
Dear All,
I am facing given below issue, Can anyone help to fix this issue.
Cisco Catalyst switch stops booting after given below process,
Using driver version 1 for media type 1
Base ethernet MAC Address: 2c:36:f8:1d:d9:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
mifs[2]: 13 files, 1 directories
mifs[2]: Total bytes     :    1806336
mifs[2]: Bytes used      :     891392
mifs[2]: Bytes available :     914944
mifs[2]: mifs fsck took 1 seconds.
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes     :    3870720
mifs[3]: Bytes used      :       1024
mifs[3]: Bytes available :    3869696
mifs[3]: mifs fsck took 2 seconds.
mifs[4]: 5 files, 1 directories
mifs[4]: Total bytes     :     258048
mifs[4]: Bytes used      :       9216
mifs[4]: Bytes available :     248832
mifs[4]: mifs fsck took 0 seconds.
mifs[5]: 5 files, 1 directories
mifs[5]: Total bytes     :     258048
mifs[5]: Bytes used      :       9216
mifs[5]: Bytes available :     248832
mifs[5]: mifs fsck took 0 seconds.
mifs[6]: 5 files, 1 directories
mifs[6]: Total bytes     :   57931776
mifs[6]: Bytes used      :   21968896
mifs[6]: Bytes available :   35962880
mifs[6]: mifs fsck took 31 seconds.
...done Initializing Flash.
done.
Loading "flash:c2960-lanbasek9-mz.122-55.SE11.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:c2960-lanbasek9-mz.122-55.SE11.bin" uncompressed and installed, entr
y point: 0x3000
executing...
2 REPLIES 2
Leo Laohoo
VIP Community Legend
Sounds like a flash issue.
Georg Pauwen
VIP Expert
check the following field notice:
http://www.cisco.com/c/en/us/support/docs/field-notices/637/fn63744.html
