11-13-2017 05:24 AM - edited 03-08-2019 12:43 PM
I have a couple if issues on my network at present and I'm sure im chassing my tail so want to verify that my port channel from my Cisco 2960 to Cisco SG300 is setup corectly. I've read a host of post's that mention Native VLAN giving problems and I also enitionaly had issue's with the Port Channel coming up but have solved that on. Anyhow here's my configuration;
-----SG300----
interface vlan 77
ip address 10.0.77.16 255.255.255.0
interface gigabitethernet1
description LAG_TO_CORE_SW
channel-group 1 mode auto
interface gigabitethernet2
interface gigabitethernet28
description LINK_TO_MG_SWITCH
switchport mode access
switchport access vlan 77
interface Port-channel1
description "PORT CHANNEL TO CS"
switchport trunk allowed vlan add 77
ip default-gateway 10.0.77.1
SG300#show interfaces status Port-Channel 1
Flow Link
Ch Type Duplex Speed Neg control State
Po1 1G Full 1000 Enabled Off Up
-----Cisco 2960--------
interface Port-channel3
description **Po-3 to MGMT Switch**
switchport trunk allowed vlan 77
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/0/2
channel-protocol lacp
channel-group 3 mode active
interface GigabitEthernet2/0/2
interface Vlan1
no ip address
shutdown
interface Vlan77
ip address 10.0.77.10 255.255.255.0
2960#show etherchannel sum
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 3
Number of aggregators: 3
Group Port-channel Protocol Ports
1 Po1(SU) LACP Gi1/0/1(P) Gi2/0/1(P)
2 Po2(SU) LACP Gi1/0/4(P) Gi2/0/4(P)
3 Po3(SU) LACP Gi1/0/2(P) Gi2/0/2(P)
2960#show interfaces port-channel 3
Port-channel3 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 50f7.2201.5c82 (bia 50f7.2201.5c82)
Description: **Po-3 to MGMT Switch**
MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is unknown
input flow-control is off, output flow-control is unsupported
Members in this channel: Gi1/0/2 Gi2/0/2
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
9924 packets input, 888899 bytes, 0 no buffer
Received 8986 broadcasts (8600 multicasts)
0 watchdog, 8600 multicast, 0 pause input
10392 packets output, 1009650 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
11-13-2017 05:51 AM
11-13-2017 08:35 AM
@Mark Malone Have edited my post now, sorry for the confusion. Assume the VLAN is 777 on both sides.
11-13-2017 08:43 AM
On one side of the link you have "switchport trunk allowed vlan add 2" and the other "switchport trunk allowed vlan 77". Could you first allow all VLANs in order to establish the link and then begin pruning?
11-13-2017 11:28 AM
11-13-2017 11:30 AM
Going to be difficult to help you working off assumptions and without a clear definition of the issue.
