WS-C3560-8PC-S Power Cable Question
Philip Denton
I feel goofy for asking this question, but...  there's only one version of the WS-C3560-8PC-S (and all other fixed-config Catalyst switches) no matter what region of the world they're deployed in, right?  The only difference region to region is the CAB-AC-<country_name> that comes with it?
I bought a pair of 3560s on the secondary market and they were new in-box but came with the strange-looking power cables pictured below.  The box said C3560-8PC-S just like I ordered though.  As long as I get my client a pair of CAB-AC= for North American use they should be fine with the switches that came in the box, right?
TIA,
Phil
Hi Phil,
The switch has internal PS and the following applies:
- The internal power supply is an autoranging unit.
- The internal power supply supports input voltages between 100 and 240 VAC.
- Use the supplied AC power cord to connect the AC power connector to an AC power outlet.
So as long as you are in range 100-240VAC from power source, there won't be any smoke :-)
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
8 Replies 8
Ivan Shirshin
Hi Phil,
Here in table 7 is the list of all 3560 switch part numbers and indeed,  there's only one version of the WS-C3560-8PC-S:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
So we're fairly certain nothing will blow up if they just use a CAB-AC= with the switches, eh?
The switch probably says something similar to:
50-60 Hz
100-240V
The US uses 60Hz power while many other regions use 50.  As far as voltage goes 110 for a typical US wall outlet and 220 for some data center / industrial stuff.
Long story short, check for those ratings on the physical switch.  I really think you're good to go though...
- Be sure to rate all helpful posts
Hi Phil,
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Sounds good, Ivan.  Thanks!
Welcome, Phil! Thanks for ratings.
Kind Regards,
Ivan
Ivan's response was strangly similar to mine...
and you got the rating too ;-)
Kind Regards,
Ivan
