ws-c3560cx-12pc-s blocked
marzi
Hi all
I've two new WS-C3560CX-12PC-S on may desk.
They were just take out of the box.
Both do not complete the post and do not reach user exec mode (>)
They are bolcked at the following message :
Nov 6 13:59:46.657: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3560CX Software (C3560CX-UNIVERSALK9-M), Version 15.2(4)E8, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Fri 15-Mar-19 12:14 by prod_rel_team
Nov 6 13:59:50.078: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
I reloaded both by turning it on and off again but I've always the same result.
Sometimes one of them take a small step forward and displays :
Would you like to enter the initial configuration dialog? [yes/no]
but it does not accept any command from the keyboard, so it is not possible to say yes or no.
Can someone help me please ?
Thank's in advance
Fabrizio
marzi
Hi all
I've solved my problem.
I can log in ws-c3560cx-12pc-s using putty.
Fabrizio
