WS-C3750G-24T and WS-C3750G-24TS Stacking possibility
Mayur Aher
I have 2  WS-C3750G-24T in stack and now 1 of switch gone faulty, and had WS-C3750G-24TS in spare , Should I replaced it with faulty one. It it compatible  stacking with  WS-C3750G-24T and WS-C3750G-24TS. what impact will be facing? kindly help
Leo Laohoo
As long as the replacement unit is running the same IOS as the ones in the stack, you should be able to stack them.
yes we upgraded the IOS  but we are confuse about model.
WS-3750G-24TS-S is compatible with  WS-C3750G-24T
BUt previous switch has 24 ports and WS-3750G-24TS-S switch has 28 ports... is it cause any issue ?
The only issue will be in the configuration:  If the configuration has those last 4 ports enabled with something.
You can mix and match any 3750 series within the same stack, however there are multiple considerations when doing so.
As Leo already mentioned (as the models are so similar), using the same IOS should permit stacking, and once the replacement unit has joined the stack you'll likely only need to configure the ports.
