02-15-2011 03:17 AM - edited 03-06-2019 03:33 PM
we want to buy the WS-C3750X-24T-S.
We need OSPF too, but I am not 100% sure if we will get OSPF with the IP BASE license.
I looked in the Feature Navigator and it says yes, the problem is when I compare IP Base (universal) and IP Services (universal) images
there is no difference in these two images.
Looking at the data sheet (http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html)
it says first:
Open Shortest Path First (OSPF) in IP Base image
but later in the same data sheet it says something different:
Cisco Catalyst 3750-X and 3560-X Series Software
• LAN Base: Enhanced Intelligent Services
• IP Base: Baseline Enterprise Services
• IP Services: Enterprise Services
Can anyone clarify this for me?
Solved! Go to Solution.
02-15-2011 04:11 AM
According to the document http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_55_se/configuration/guide/swiprout.html#wp1483229
With Cisco IOS Release 12.2(55)SE, the IP Base image supports OSPF for routed access. The IP services image is required if you need multiple OSPFv2 and OSPFv3 instances without route restrictions. Additionally, the IP services image is required to enable the multi-VRF-CE feature.
OSPF for Routed Access is specifically designed so that you can extend Layer 3 routing capabilities to the wiring closet.
Note OSPF for Routed Access supports only one OSPFv2 and one OSPFv3 instance with a combined total of 200 dynamically learned routes. The IP Base image provides OSPF for routed access.
However, these restrictions are not enforced in this release.
Hope this helps.
Cheers!
02-15-2011 04:11 AM
Hope this helps.
Cheers!
02-15-2011 04:21 AM
Thanks for the link. It helped a lot.
02-15-2011 04:35 AM
No worries! Please mark the thread as resolved to help others as well
