WS-C3750X-48PF-S connection with HP DL380Gen8
dvigny-hwrt
I would like to connect a DL380Gen8 to a Cisco 3750X using 10G.
On  HP side, i have a Ethernet 10Gb 2-port 530FLR-SFP+ Adapter (without any  SFP) and a WS-C3750X-48PF-S + a C3KX-NM-10G= module (without SFP).
What kind of cable and/or SFP are suitable to connect everything together ?
Thks
DV
Reza Sharifi
It depends on your distance.  If the HP is less than 500 meter from the switch than you need Multimode SFP and Multimode Fiber, if it is more than you SM SFP with SM fiber.
how far apart are they?
