03-26-2018 02:52 PM - edited 03-08-2019 02:24 PM
Hello all,
I have a WS-C2850-24U being monitored by our system.
We are receiving alerts that our "Switch 1 - Power Supply A Container" is currently "off ( other)".
We also see values for "Switch 1 - Power Supply A Normal" and "Switch 1 - Power Supply B Normal" to be "normal".
The OID that is being used to monitor the Power Supply A Container is: cefcFRUPowerOperStatus
While the OID that is being used to monitor the Power Supply A/B Normal is: ciscoEnvMonSupplyState
These values are being retrieved by our monitoring system from the switch via SNMP.
show environment power all SW PID Serial# Status Sys Pwr PoE Pwr Watts -- ------------------ ---------- --------------- ------- ------- ----- 1A PWR-C1-1100WAC LIT204424AK OK Good Good 1100 1B PWR-C1-1100WAC LIT20443KGX OK Good Good 1100
We cannot find anything wrong with the power supplies on this switch ( nothing in logs), so we are at a loss.
What does Power Supply A - Container refer to? Is it different from Power Supply A Normal?
And does this indicate something is wrong with our power supplies - or perhaps we are misinterpreting it.
Any suggestions would be great.
Thank you,
Vivia
07-12-2022 07:47 AM
Same problem here, but 3850 and 48 ports.
07-12-2022 09:40 AM
That is a bug in the version of the software you are running. If you upgrade, the issue most likely will go away.
07-12-2022 09:19 AM
- Sometimes this is related to software bugs , use latest advisory release for your model , check if that can help.
M.
