WS-C4506 Faulty Module After Outage
amongoiano
Ive been having a problem recently with a Catalyst 4506 here is the description of the problem:
     Over the past couple of months there was a couple of power outages in the building bringing the switch offline. When the switch comes back up we are seeing that some of the linecards are failing start up tests. I have to go in and physically pull the linecard out and re-insert it, because resetting it through the cli doesnt fix the problem.  We are in the process of getting this room backed up by our building UPS, but right now that is not the option.
     I read over the release notes for the current OS version and no issue popped out resembling this problem.
Has anyone dealt with this before and found a fix for it?
below is the info extracted from the switch.
OS Version:
cat4000-i9k91s-mz.122-18.EW2.bin
CS-4OW1E#sh mod
Chassis Type : WS-C4506
Power consumed by backplane : 0 Watts
Mod Ports Card Type                             Model             Serial No.
1     2 1000BaseX (GBIC) Supervisor(active)   WS-X4515           JAE0834TWM3
2   48 10/100/1000BaseT (RJ45)               WS-X4548-GB-RJ45   JAE0840XL2V
3   48 10/100/1000BaseT (RJ45)               WS-X4548-GB-RJ45   JAE0841XQPD
4   48 10/100/1000BaseT (RJ45)               WS-X4548-GB-RJ45   JAE0841XUVD
5   48 10/100/1000BaseT (RJ45)               WS-X4548-GB-RJ45   JAE0841XUMK
6   48 10/100/1000BaseT (RJ45)               WS-X4548-GB-RJ45   JAE0841Y17T
M MAC addresses                  Hw Fw           Sw               Status
1 0011.bb37.72c0 to 0011.bb37.72c1 4.0 12.1(20r)EW1 12.2(18)EW2     Ok
2 0012.01f4.2f20 to 0012.01f4.2f4f 0.1                               Ok
3 0012.4360.aff0 to 0012.4360.b01f 0.1                               Faulty
4 0012.4360.e080 to 0012.4360.e0af 0.1                               Faulty
5 0012.4360.e170 to 0012.4360.e19f 0.1                               Ok
6 0012.4360.e890 to 0012.4360.e8bf 0.1                               Faulty
CS-4OW1E#
Thanks in advance!
Somasundaram Jayaraman
Hi ,Amon
from the outputs pasted above i see some of the modules are showing faulty status in show module ouptut.
Please make the diagnostic level as complete and reseat the card.
Command to make the diagnostic level as complete would be
conf t
diagnostic bootup level complete
Once the diagnostic level is complete, hard reseat the card and share the outputs of "show diagnostic result module all detail"
This result will tell us whether there is any hardware issue with the line card or not.
You can issue hw-module module reset command in order to soft reseat the card.
Hope this helps.
Cheers
Somu
