WS-X4612-SFP-E on a non 4503 chassis
alig.norbert
Level 4
Level 4
Hi all,
Guess I know the answer ;-(
Can a WS-X4612-SFP-E be put in a non 4503 chassis?
- The "show modules" shows "unsupported module"
- Chassis Type :   WS-C4503
- Sup card:            WS-X4013+TS
- IOS:                    Version 12.2(25)EWA8
How about a new chassis, 4503-E? Does the WS-X4013+TS still supports PBR?
Norbert
2 Accepted Solutions
Ivan Shirshin
Hi Norbert,
This card is only supported on E-series chassis (including 4503-E) with sup6 or sup7. See table 1:
http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea.html
Cisco Catalyst 4500 46xx E-Series Line Cards
24 Gbps
Cisco Catalyst 4503-E, 4506-E, 4507R-E, 4507R+E, 4510R-E, and 4510R+E2
Supervisor Engine 7-E,
Supervisor Engine 7L-E,
Supervisor Engine 6-E,
Supervisor Engine 6L-E
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Hi Leo,
This supervisor actually supports 4503-E:
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps6013/product_data_sheet0900aecd8017a0c5.html
"Exclusive to the Cisco® Catalyst® 4503-E and 4503 Switches chassis, the Cisco Catalyst 4500 Series Supervisor Engine II-Plus-TS"
Kind Regards,
Ivan
Kind Regards,
Ivan
9 Replies 9
Ivan Shirshin
Hi Norbert,
24 Gbps
Kind Regards,
Ivan
Kind Regards,
Ivan
So, no way to re-use WS-X4013+TS on th 4503-E chassis, right?
Norbert
Hi Norbert,
You can use WS-X4013+TS supervisor on 4503-E chassis and it will work (as they are compatible) but it won't support WS-X4612-SFP-E card.
Kind Regards,
Ivan
Kind Regards,
Ivan
Nope.  You can use the supervisor card on older non-E chassis.
Hi Leo,
Kind Regards,
Ivan
Kind Regards,
Ivan
So, WS-X4013+TS is supported on 4503-E chassis, but the line card is not supported
with 4013+TS on that chassis.
Thank you,
Norbert
That's correct, Norbert. Welcome!
Kind Regards,
Ivan
Kind Regards,
Ivan
Thanks Ivan!
welcome :-)
Kind Regards,
Ivan
