X2-10GB-SR compatible with GLC-SX-MM??
mkashifashraf
Dear all,
one side Catalyst 6500 module with X2-10GB-SR=
otherside WS-C2960S-48FPD-L.
is both end compatible with each other.
acampbell
You can not inter connect these 2 transceivers.
X2-10GB-SR is for operating at 10G
GLC-SX-MM is for 1G
They need to be the same speed and fibre type
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
WS-C2960S-48FPD-L uplink is SFP+, can we connect GLC-SX-MM on SFP+ ports??
From this link
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd80322c0c.html
Cisco Catalyst 2960-S with SFP+ based ports:
• 10BASE-T ports: RJ-45 connectors, 2-pair Category 3, 4, or 5 unshielded twisted-pair (UTP) cabling
• 100BASE-TX ports: RJ-45 connectors, 2-pair Category 5 UTP cabling
• 1000BASE-T ports: RJ-45 connectors, 4-pair Category 5 UTP cabling
• 1000BASE-T SFP-based ports: RJ-45 connectors, 4-pair Category 5 UTP cabling
• 1000BASE-SX, -LX/LH, -ZX, -BX, -T,* -FX,* and coarse wavelength-division multiplexing (CWDM) SFP-based ports: LC fiber connectors (single/multimode fiber)
• 10GBASE-LR, SR, LRM, CX1 SFP+ based ports
* The Cisco Catalyst 2960-S with SFP+ does not support the GLC-FE-100BX, GLC-FE-100FX, or GLC-FE-100LX.
So yes the switch should support GLC-SX-MM
Also
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html#wp128965
WS-C2960S-48FPD-L
WS-C2960S-48LPD-L
WS-C2960S-24PD-L
WS-C2960S-48TD-L
WS-C2960S-24TD-L
GLC-SX-MM
GLC-LH-SM
GLC-ZX-SM
GLC-BX-D
GLC-BX-U
CWDM SFP
GLC-SX-MMD
GLC-LH-SMD
12.2(53)SE1
Alex.
The 2960S SFP+/SFP ports can take either, HOWEVER, you still can't connect an SFP to an SFP+ because both run on different speeds.
