11-25-2010 04:42 PM - edited 03-06-2019 02:13 PM
I have a Windows 7 Media Center PC on the same LAN (192.168.x.102 and 192.168.x.107) both plugged into a 3548 XL. I know that the streaming wants multicast and UPnP, but the UPnP wouldn't be something I'd be checking on a switch. The router is an 881W, and I've enabled routing and multicast. I don't see anything on the 3548 XL specifically for multicast - is it on by default? Do I need to do anything with IGMP? The 881W does have firewall capability, but I'm pretty sure it's off by default. The firewall on the Windows 7 machine is off. Any suggestions?
Scott
11-25-2010 06:42 PM
If your connections are in the same subnet nothing has to be done on the 3548.
12-19-2010 07:26 PM
Didn't think so. Turned out that I had to delete an old Media Center pairing and reboot the Xbox.
