08-27-2007 11:52 PM - edited 03-05-2019 06:08 PM
Hi is there a maximum power receive for a
XENPAC-10GB- LR ? In the Cisco specification is only the minimum power receive of -8.2dbm
thanks for replay
markus
08-28-2007 12:47 AM
The datasheet gives the following values:
Max Transmit Power 0.5dBm
Min Transmit Power -8.2dBm
Max Receive Power 0.5dBm
Min Receive Power -14.4dBm
Link here:
http://www.cisco.com/application/pdf/en/us/guest/products/ps6574/c1650/ccmigration_09186a008007cd00.pdf
The confusion arises because the html table is corrupted - use the above pdf link as the correct reference.
Andrew.
Log in to Community
