Cisco 1800 router
how do i reset my Cisco 1800 to factory settings ?
Tim Y
Hi there,
Just log into it and issue a delete startup-config from Privileged Exec mode.
Example: Router#delete startup-config
If you cannot log into the router, then you need to do a password recovery. You can follow the guide here to learn how: http://www.internetworkingcareer.com/blog/perform-password-recovery-cisco-routers/
I hope this helps.
Tim
