Visio Stencil for NIM-2GE-CU-SFP
ericveed1
We are trying to document probable configurations for replacing our 2900 and 3900 Series Routers with 4300 and 4400 Series Routers. Several Stencils are notably missing from the Stencil Library. 1) The redundant Power Supplies for the 4431 Router and 2) The NIM-2GE-CU-SFP Module.
Any help in having the Stencils created would be appreciated
Palani Mohan
Hi Eric
I am going to assume you looked into
http://www.cisco.com/c/en/us/products/visio-stencil-listing.html
but did not find stencil/icons for 1) The redundant Power Supplies for the 4431 Router and 2) The NIM-2GE-CU-SFP Module.
Would this be a safe assumption?
If yes, let me know and I can approach the Cisco business folks to see what can be done.
Kind regards .... Palani
7 Replies 7
Palani Mohan
Hi Eric
Hi Eric
Regret the delay. Still working on identifying the correct group/folks.
Kind regards ... Palani
Hi Eric
Very very slow progress from our end. Regret inconvenience caused. I have got traction with the team that handle this. Our product team is working on adding stencils for other missing parts. Neither NIM-2GE-CU-SFP nor PWR-4450-DC/2 or PWR-4430-DC/2 are in the proposed list.
Right now, we are discussing what it would take to add these missing to the "work in progress". Please hang in there for my next update.
Hi Eric
You have been very patient. Thank you. I am unable to upload the VSS file indirectly. I could not upload if the extension was vss. So, I changed the file ext to doc. After downloading, please change from doc to vss and you will be able to access the template.
Let me know if you it is not working for you and I can think of alternate options.
Is there a similar Visio with the NIM-16A cards?
Is there a similar template (.vss) with the PWR-4330-DC?
Thank you,
Ken
ericveed1
Palani
Correct, I was looking in the "Routers - ISR 4000" (ZIP - 4 MB)  09/Aug/2016 Zip file for both items. I also searched other Zip files of routers that support NIM Modules to see if the NIM-2GE-CU-SFP might be contained in another location but wasn't able to locate it.
I would appreciate it if you could get them created
Thanks in Advance -- Eric
