2900 , 3900 Gen 2 routers
adnan.akbar
does the ISR 3900 Gen 2 router has any video over ip features or advantages over the 2900 ?
i have an overseas branch connected to my centralized CUCM via a leased line  with a number of phones and 1  telepresesnce end point , im not sure whether to go with the 2900 or the 3900  ?
can anyone help me on that
regards ,
Michael O'Brien
We will need a bit more info to determine which router is the best fit for your branch office.  You should consult your local SE for these design and implementation related questions.  There is a BIG difference between the 2900 and 3900 both in price and performance. (3925, 3945, 2951, 2921, 2911, 2901)
The 3925E (G2) is generally 2-4 times faster than the 3925 (G1) depending on application, so this means the 3925E can handle alot more data or media sessions than the 3925.  Also the 3925E can server twice the number of IPSec/AES Tunnels as the 3925. And the 3925E can handle
3 and a half times more IPSec tunnels than the 2921.
Before choosing an ISR for your application we must determine what applications besides the TP and IP phones at this location.  We have many design guides available on cisco.com Website which can help you make design related decisions.
Cheers
http://www.cisco.com/en/US/partner/prod/collateral/routers/ps380/C96-582851-00_ISRG2_ST_v2b.pdf
thanks Michael , i have noticed the difference between the two categories . however i could not find anything related to rich media  features.
im only using the Branch for those 5 phones and 1 TP , no other services on the branch , not even internet access .  as a quick recommendation  , would you go for the 2900 or the 3900 ?
Hi Adnan, this seems like a small office environment, in which the 2900 series routers can
work very well for you.  Since TelePresence will be one of your biggest applications I have
added a link for you to look at the TelePresence Design Guide which will help you understand
the network and bandwidth specifications.  The "Branch QoS Design for TelePresence" section
will guide you with QoS configurations.
Cheers
http://www.cisco.com/en/US/partner/docs/solutions/Enterprise/Video/TP-Book.html
paolo bevilacqua
Have you ever considered consulting with an expert to help you with purchasing decisions and network desing ?
