06-08-2009 03:45 PM - edited 03-17-2019 09:45 PM
Our VC units use ISDN links, we'd rather utilise the 3800 router to terminate VC IP end points. Can this be done?
Polycom VC Units
3800 - Cisco IOS Software, 3800 Software (C3845-SPSERVICESK9-M), Version 12.4(8d), RELEASE SOFTWARE (fc2)
Thanks for your time.
Solved! Go to Solution.
06-08-2009 10:05 PM
06-08-2009 03:48 PM
Yes, it can also terminate isdn video calls.
06-08-2009 03:51 PM
Would you be able to point me to a paper on how this is done by chance?
Thanks again
06-08-2009 05:47 PM
What type of endpoints are these? PRI, BRI, H323, SIP, SCCP, etc?
-nick
06-08-2009 06:57 PM
H323, we briefly looked into this about 18 months ago, from memory they said we need an additional PRI? Can't recall...
The VC units are using ISDN BRI currently. We want to rid ourselves of the BRI Rates and use the network via the 3800 doing the translations.
This might be a bit over my head :)
06-08-2009 10:05 PM
