02-26-2013 12:14 PM - edited 03-18-2019 12:39 AM
We've deployed 9971 phones, and are beginning to mess with the video cameras. Our person in one of our west coast offices can't dial certain off-net phone numbers when the camera is enabled, though. Specifically, it seems to affect toll-free numbers. But, i've got the same phone/camera setup and i can dial everything perfectly fine...
callmanager version is 8.5.1, firmware is 9-3-2-ES1, but it hasn't worked with previous revs of firmware either.
Any ideas anyone?
02-28-2013 03:00 AM
Hello Scott,
what kind of pstn connection are you using?
Maybe you could have a look if the gateway is trying a video call.
02-28-2013 01:48 PM
if you are using PRI, add beare-cap speach under controllet configuration.
Anas
please rate if it is helpful
02-28-2013 01:56 PM
Hi Bernhard--PRI for PSTN.
Anas--i'm trying to find where to add that particular command. i know i've seen it before, but i can't get it to show up under the serial 0/0/0:23 interface or the controller 0/0/0 option either...it's been a while...
03-05-2013 08:45 PM
Try under the voice port.
03-06-2013 05:49 AM
Ah! You're spot on Tony. Thank you!
I'll let you know if this works.
SJ
