03-27-2017 02:01 PM - edited 03-18-2019 12:56 PM
If I order t
I only need
Solved! Go to Solution.
03-27-2017 04:17 PM
According to the screenshot you uploaded, you have WebEx options you can select without Spark Meet. Also, just below those options, you can select others WebEx centers (Event, Support, Training) that you need with Meeting Center.
03-27-2017 04:17 PM
03-27-2017 04:22 PM
You can
Try to build the config in CCW and you will see.
03-27-2017 04:41 PM
I'm not sure, suggest you contact your Account Manager, they can help build out what you need and get the appropriate quantity of host accounts you need.
03-27-2017 08:57 PM
Below is a
The Annuity A-WX licenses include Spark by default and it is not removable.
The "Without Spark" option is only available for countries that are not certified to sell Spark.
Adding Spark will not incur
