ADD EX90 TO CM (sip)
Chet Cronin
Level 4
Level 4
We are running UCM 8.6.1.2006
EX90 TC7.3.0
Unable to get the EX90 to register with the CM ???
Error on the EndPoint is provisioning - HTTP -404
Any help is appreciated ...
Verified Provisioning connectivity is Auto
httpmethod is GET
Home SIP Status is inactive
Chet Cronin
Manish Gogna
Hi Chet,
A couple of points:
1. Check if the Directory Number has been configured on CUCM if adding manually.
2. CUCM 8.6.2 or higher is recommended as per the datasheet for EX series.
Manish
7 Replies 7
Manish Gogna
Hi Chet,
A couple of points:
Manish
Hi Manish,
Sorry for asking questions in others thread. I have an EX60 with TC4.1 in Lab. I need to register this EX60 natively to CUCM 10.5. I know CUCM native registration is supported only from TC5.x. The issue is that I don't have the service contract. It's expired. So if I upgrade my system to 5.1, will it cause some issues? Regarding the Release Keys?
Thank You
Abdul Rasheed
Hi Abdul,
You will need the release keys for new version
https://supportforums.cisco.com/discussion/11363421/ex60-upgrade-50-421
Manish
Thanks Mr. Manish. Can I register this one to VCS?
Yes, it can be registered to VCS, please check the minimum recommendations though.
Manish
Thanks Mr. Manish,
Do we need TMS and provisioning extension for ex60 registration?
Thanks for your support.
Abdul
You can register the EX90 to VCS with and without TMS/TMSPE, it all depends on how you'd like to deploy the endpoint, and if the VCS is setup to authenticate registered endpoints, suggest you take a look at the VCS Authenticating Devices Deployment Guide (X8.7).  TMSPE can help automate the provisioning and deployment process for the EX90, refer to the TMSPE with Cisco VCS Deployment Guide (1.6) for more information.
