ANI and DNIS over a T1
jbouwkamp
I am trying to route incoming 800 calls over a T1 connecting to a 3640 router to a Call Manager. The 800 number calls come in with a 4 digit tag such as 7405. My problem is what shows up in the called number field is *2125551212*7405*. This is basically the caller ID information and then the 4 digits sent to allow us to route the call. The problem is that the router sees it as all the called number. What am I doing wrong?
I am using a typical
ds0-group 0 timeslots 1-24 e&m-winkstart dtmf dnis command.
Any help would be appreciated...
pradeepde
Level 5
Level 5
Not sure if its same for 3640 also, but I do have a link for AS5840 explaining the config for T1 CAS for VOiP. This also includes the ds0-group 0 command in it.
Configuring T1 CAS for Voice over IP on the Cisco AS5800 and Cisco AS5850
http://www/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a00800b5d44.html
