01-24-2018 07:39 AM - edited 03-18-2019 01:47 PM
Greetings,
We have our unit connected to an older Samsung plasma TV. It recognizes the HDMI input, but refuses to display it just displaying an error "Not Supported Mode". Looking into it further, it states that the error is displayed when an device is plugged into the TV with an unsupported resolution.
Thanks!
Solved! Go to Solution.
01-29-2018 08:23 PM
@Wayne DeNardi wrote:
Unfortunately, this option doesn't seem to appear in the latest CE9.2.x releases. The only option available in the web interface is "Auto".
Hm, I must have been looking at the wrong admin guide at the time then, thanks for catching that!
01-24-2018 07:55 AM
I believe older SW versions allowed you to set to 720p instead of default, but newer ones do not, auto is the only option. Generally they will negotiate with a 720p monitor and work, but it sounds like the one you have isn't cooperating, you'll either need to downgrade the endpoint software or replace the monitor with something more current.
01-24-2018 08:43 AM - edited 01-29-2018 08:24 PM
You can change the resolution of the HDMI output via the web interface, see Video Output Connector [1] Resolution in the SX10 Admin Guide that matches your software version.
EDIT: It's not possible to set output resolution on SX10 endpoints, only with SX20 and higher.
01-29-2018 06:39 PM - edited 01-29-2018 06:41 PM
Unfortunately, this option doesn't seem to appear in the latest CE9.2.x releases. The only option available in the web interface is "Auto". Even the CE9.2 SX10 Admin Guide (page 128) says:
Define the resolution and refresh rate for the connected screen. This value is fixed and
cannot be changed.
Default value: Auto
Value space: Auto
Auto: The system will automatically try to set the optimal resolution based on negotiation
with the connected monitor
01-29-2018 08:23 PM
