01-13-2019 03:54 AM - edited 03-18-2019 02:34 PM
Hi Guys
do i need to have new options key when i need to update expressway from 8.10 to 12.X , doing that and it asks for new option key
thanks
Solved! Go to Solution.
01-13-2019 04:24 AM
Hello Ibrahim,
Yes, you need a release key to upgrade to X12.5.
This is mentioned in release notes-
Please rate if it is helpful...
01-13-2019 04:24 AM
Hello Ibrahim,
01-13-2019 05:02 AM
thanks bro
01-24-2019 12:23 AM
How do you get a X12 release key? I cannot seem to select a specific version when I use PUT to get an upgrade license.
Ruud
01-28-2019 12:27 AM
It is available by entering the serial key from the request of TelePresence software key of Product License Registration.
https://slexui.cloudapps.cisco.com/SWIFT/LicensingUI/Quickstart#
01-28-2019 01:56 AM
Won't that just give me another 8.X release key? I need to fill in a Release Key when upgrading, but I assume I will get a 8.X key when I use the current server's virtual MAC to get a key from the License Portal.
01-28-2019 04:18 PM
If you go to the Product Licencing link suggested above, you then select "Get Licences", then Request TelePresence Software Release Key", put in your serial number, then there will be a drop box under "Change to:" which you can change to the release you want (ie X12.5.0)
01-28-2019 11:20 PM
That did the trick, thanks! I was trying to register an Expressway PAK, which didn't allow me to select a version. Your method indeed shows a dropdown box for the requested license version.
