10-20-2017 08:45 AM - edited 03-18-2019 01:33 PM
Hi Guys
I trying to integrate Ayava Scopia with CUCM-Expressway, unsuccessfully.
Who has make this integration before?
CUCM version 11.5
Expressway Version: X8.9.1
TIA
Cristian
10-20-2017 09:20 AM
You probably want to explain what you're trying to achieve to get help.
10-21-2017 03:22 PM
Jaime..sure.
The client need make video calls from a Avaya Scopia to Cisco DX80 and for both way.
How to do this?
TIA
Cristian
10-22-2017 04:44 AM
you should be able to achieve this using URI dialing, so for instance +551187282@company.com
and your DX80 has the +551187282@company.com configured on it.
VCS express way is the device of choice for this.
from your CUCM you should have a wild card URI route pattern pointing to your VCS
10-23-2017 07:07 AM
Dear Dennis
I will follow your recommendation
10-23-2017 07:55 AM
Dear Dennis
I´m trying to call point to point from DX80 sip:57010@161.131.210.236 to Avaya URI sip:635728@xconference.xxxxxx.xx . In the expressway show the Status: 404 Not Found
The Avaya Scopia model is XT5000
TIA
Cristian
10-23-2017 11:21 AM
Then
Here I have registered 2 Avaya Scopia in Expressway:
Here I have the call from DX80 to Avaya Scope (58001@IP address):
Here I have the call from DX80 to Avaya Scope (58001@DNS):
Evento log:
Here the config of Avaya Scopia
TIA.
Cristian
11-02-2017 06:05 AM
11-06-2017 12:33 PM
The status is the follow:
The left call is from XLIte registered in the Expressway-C and call to Avaya Scopia registered in the Expressway-C
The right call is from DX80 registered in the CUCM and call to Avaya Scopia registered in the Expressway-C
12-20-2017 11:24 PM
Hi All,
we have also same issues in our Scopia xt5000 with Scopia Pathfinder environment to remote end having cisco express E&C with CUCM with DX80 model endpoint and find the below Call Topology.
our end Scopia Call topology:
from our end Scopia Endpoint XT5000 model -> (Gatekeeper ->) Scopia 6xxx series Pathfinder Server (PFS) -> remote end express E&C with CUCM-->DX80 Endpoint model
Remote end Call topology:
Cisco express E&C (8.10version) with CUCM(version 11.5.1.12900-21)--->DX80 endpoint Or Scopia Xt5000 with 8.3.4
Our case its not able to establish the media.the same we have installed polycom Desktop real presence in my laptop connecting through Airtel Dongle it was working.
12-21-2017 05:02 AM
Scopia's Iview allow CUCM to work as a third party SIP server. Scopia iView has a B2BUA and a gatekeeper to work with Scopia Elite MCU(both SIP and H.323), which has the Cisco telepresence option.
Because cisco/Tandberg has the proprietary H.264 redundancy, which needs elite MCU.
The XT5000 and PathFinder are supposed to be managed by the iView. Right now, Avaya has released software version MCU VMware, Equniox Server. It works together with Equinox Management(iView) and EdgeH323(PathFinder).
