Bandwidth consideration for Video traffic
kianhowtan
I had two remote sites that are using 3845 routers, with 4 E1 links linking both sites.
I had a server that will be sending approx 4M size of video traffic from site A to site B.
I am thinking of using MPPP to bundle 2*E1 to cater the 4M video size.
I need some advice whether this is workable?
smahbub
Level 6
Level 6
Using MultilinkPPP is a good option in your scenario. You can also go for some QOS mechanisms.
http://www.cisco.com/univercd/cc/td/doc/cisintwk/ito_doc/qos.htm
